Results 1 to 5 of 5
Thread: "Automated" stop for a lathe
24th Oct 2021, 11:01 AM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,183
When someone can't be bothered taking the control panel off to wire an extra e-Stop micro-switch in:
Video link, which might not work: https://photos.app.goo.gl/oGcbKZ4Jpuz1KNwKA
24th Oct 2021, 11:59 AM #2Member: Blue and white apron brigade
- 7,182
Ingenious
BUT
Just playing devil's advocate for a bit
The whole thing looks like it might get in the way generally, and more importantly get in the way of a real emergency stop.
I assume it's compressed air driven? but what happens if (for whatever reasons) there's no air?
eg Forgot to check if compressor is on, or valves open, or for some reason compressor has stopped working. etc
Of course a daily test is in order, but in between testing and later in the day . . . . . .?
24th Oct 2021, 06:40 PM #3
Someone has obviously spent a lot of time and effort to build that contraption without giving it a lot of thought ! It surely would have been safer to have removed the panel and extended the wiring to a remote switch, without blocking access to the Estop.Best Regards:
24th Oct 2021, 08:43 PM #4Diamond Member
- Aug 2019
- 56
- 1,183
Bob: Yes, air driven. The air line snaking along the floor was stolen from the blow gun of a CNC mill.
He usually has air on when using any machines, but yes, mistakes can happen –
I'd be testing the air valve and actuator each time I loaded new stock into the chuck.
I think bashing the Aluminium box section forward would still hit the e-Stop.
Baron: Only took him about 45 minutes, and that included two trips walking down to my unit; to get some M4 fasteners, and to get an 1/8" to 1/4" BSP reducer (and to have a Friday afternoon beer)!
I proposed an electrical micro-switch, but he already had the air valve and actuator, and wanted to try them.
31st Oct 2021, 09:10 PM #5Diamond Member
- Aug 2019
- 56
- 1,183
He made it even simpler; no air feed required, it now just knocks the feed select lever off:
https://photos.app.goo.gl/6TcXfLBtSPHFe9XU9
https://photos.app.goo.gl/HWtK24vkg6yE2MbD7
A friendly "GUTEN TAG" from Austria (you know, the one lacking the "L")
By nanno in forum G'day mate - THE WELCOME WAGON -Introduce yourselfReplies: 6Last Post: 2nd Jul 2021, 05:33 PM -
"How to make a stop block assembly"
By KBs PensNmore in forum METALWORK GENERALReplies: 14Last Post: 15th Feb 2015, 01:23 PM -
WEST AUST Hercus metal lathe 12" x 42" excellent condition
By craig manley in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 6th Jul 2011, 02:29 AM -
Ipswich rail museum "big lathe"
By new_guy90 in forum METALWORK GENERALReplies: 19Last Post: 22nd Jan 2011, 02:02 PM -
Difference "Galvanised" and "Primed" Steel
By Fr_303 in forum METALWORK GENERALReplies: 4Last Post: 22nd Jan 2008, 05:59 PM
