Results 1 to 7 of 7
    Aug 2011
    4,779
    Default A Solar Tracker For My Campimg Solar Panel
    Inspired by a fellow camper on another forum, I decided to make a Solar tracking system for my 200w Solar panel.
    With Solar panels so cheap nowadays, Solar tracking systems have lost alot of their benefits. It's cheaper to just install more panels than to build/purchase a tracking system.
    However when it comes to camping, Solar panels are not necessarily easy to store so adding a compact tracking system can yield around 30% more energy from the same panel. It's also fun to watch!
    The brains of the setup is a single axis solar tracking module, bought on eBay for $70 delivered.
    It outputs power to a 12v actuator to move the panel as required.
    The module is supposed to be powered from an independent source but I have powered it directly from the solar panel. The panel only needs to generate 20w of its 200w potential for it to track the sun.
    When packed up, the from folds flat inside the rear of the panel taking up no space. The ground support poles unscrew in two pieces and store in some pipe.
    System takes 5 minutes to set up.
    Aug 2011
    4,779
    Here's a pic
    Apr 2018
    Drouin Vic
    634
    Great job, I've been wanting to do this for years but only ever think about it when we're camping. I'll have to look into that system.
    6,475
    Hi Simon,
    A chap we saw in France a couple of years ago was using a satellite dish mount on his camper to erect the panel and track the sun ! Quite interesting watching it working.
    Aug 2011
    4,779
    Here's a screen shot of the tracking module that drives the system.
    It was pretty straight forward to wire up. From a metal working POV it's about as basic as a project gets on this forum but the design was a bit fiddly because I wanted everything to stow away compact, be reasonably light and not take a long time to set up. Oh, and stand up to strong winds, which it does.
    Looking at the frame, I can already see improvements that can be made. The frame can be made simpler and lighter. This one is a little over-engineered.
    May 2021
    Surrey
    14
    Default Archimedes tracking of solar panels
    I know this thread has been out there long enough to have grown cold, but I worked in PV. for many years, including a a tracking system that had no moving parts. In essence a panel was set up facing the noon sun but on trunnions so it could rock to face to face the morning sun and so on. What moved the panel was along the two east west sides were a pair of 50mm steel tubes shaded partially by outward facing reflectors the tubes were linked by a small bore tube. The whole was then half filled with liquid butane. If the array was off axis that side that was more shaded and the liquid gas would move across to rebalance the array till equilibrium was achieved. It worked well as long as it wasn’t windy. If it was then a double acting actuator was used. If you are interested in more details ask and I’ll dig out some old photos. QUOTE=simonl;1990105]Inspired by a fellow camper on another forum, I decided to make a Solar tracking system for my 200w Solar panel.
    Sent from my SM-G970F using Tapatalk[/QUOTE]
    Aug 2011
    4,779
    Hi Blackpig,
    Thanks for sharing. While doing some research on this topic I did see a similar setup. Interesting concept for sure however not practical for camping.
    Sent from a galaxy far far away
  1. Remote Solar Panel Systems
    By Karl Robbers in forum ELECTRICALS
    Last Post: 29th Nov 2020, 07:44 PM
  2. Free-Electronics/Electrical/Solar parts
    By racingtadpole in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 18th Nov 2020, 10:11 AM
  3. Wind/Solar Power.
    By YBAF in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 12th Jun 2016, 12:18 AM
  4. Solar panel indexer
    By Steamwhisperer in forum METALWORK PROJECTS
    Last Post: 8th May 2016, 08:23 PM
  5. Solar Inverter Sun Screen
    Last Post: 22nd Feb 2015, 10:07 PM
