Results 1 to 6 of 6
Thread: HEBCO Grinder refurbishment
17th Sep 2021, 12:44 PM #1New Member
- Sep 2021
- Toowoomba
- 72
- 7
Hi All This grinder was acquired by the previous owner for scrapping and he already scrapped the copper from the motor The grinder was not in good shape as per the pictures below. The motor was missing but the end casings were there. Most of the bits were there but rusted bent or broken. It stood in my yard for a while while my workshop was built, and the project bubbled up to the top of the pile. The first hurdle was getting the arbour nuts off the arbour as they were severely rusted on. Lots of beatings happened to no avail. Lots of rust products were tried to no avail. I let is stand for a while then hit it with MAPP gas and a big rattle gun and it came free for both nuts. Then i had to remove a bearing from one journal so i could feed in two new drive belts and reassemble the drive belts on the arbour pulley. I had a spare motor that came off a floor drill but i was told that it was 110 volt but on closer inspection it was actually a dual voltage motor 110 240 so I had it rebuilt and wired to a 3 pin plug and cord. Next i had to design and build a mount for the motor as that was missing however when i tried to fit the motor in the stand it was obvious the belts were too short. So disassemble the bearing buy and fit two new longer belts and reassemble the arbour. The motor mount was fabricated but i had mounted it a little too low but a nice set of machinery feet solved that problem. i ordered an emergency on off switch and wired that up in the original hole but it sticks out a little. I bought a new wire and grinding wheel fitted and tested the build so far, it worked fine. It seems that when this grinder was made that end shields and eye shields were not required so i had to fabricate them. This required me to use the plasma cutter and MIG to cut and fit them. The eye shields fell off a display stand and they work well as your hands fit in the Great Australian Bight. The last hurdle was to weld the cast iron tool rest back together. It has been 40 years since i last welded cast iron, not a lot of cast iron on the helicopters i worked on. I practiced on a broken vice and when i felt brave enough i welded the tool rest back together. It is not perfect so i painted it black to hide it. It now stands finished in my welding bay. Regards Steve
17th Sep 2021, 03:37 PM #2Senior Member
- Dec 2009
- 327
Great save!
My favourite type of grinder- big! A bit easier to use when you just have to lean your body-weight on the job, into the wheel.
Probably super sell-able, now it has a 240v motor.
regs,
AndrewOC'Waratah' spring hammer by Hands & Scott c.1911- 20, 'Duffy, Todd & Williams' spring hammer c.1920, Premo lathe- 1953, Premo filing machine.
17th Sep 2021, 06:14 PM #3New Member
- Sep 2021
- Toowoomba
- 72
- 7
12th Oct 2021, 11:33 AM #4Senior Member
- Jul 2014
- melbourne
- 110
looks great, will last another hundred years
7th Nov 2022, 09:53 PM #5Golden Member
- Aug 2015
- Melbourne, Australia
- 843
lovin' those Aussie shaped shields. gold!
8th Nov 2022, 11:54 AM #6New Member
- Sep 2021
- Toowoomba
- 72
- 7
HEBCO Switch and Plate
By Betnorm in forum WANTED TO BUYReplies: 2Last Post: 17th Sep 2021, 02:22 PM -
Anvil Refurbishment and Repair
By Ted Hobson in forum GENERAL DISCUSSION / OFF TOPICReplies: 10Last Post: 15th Jan 2020, 08:18 PM -
Layshaft Bearing refurbishment
By Frank Courtney in forum THE HERCUS AREAReplies: 4Last Post: 29th Nov 2019, 12:55 PM -
Hercus Drill and Hebco grinder
By Ueee in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 26th Aug 2014, 12:27 AM -
Machine Vise Refurbishment
By Anorak Bob in forum METALWORK GENERALReplies: 10Last Post: 29th Jan 2013, 10:25 AM
