Results 61 to 75 of 75
Thread: Mystery Project. What is this???
27th Apr 2023, 07:58 PM #61
Most Valued Member
- 4,870
It's material out of your junk bin.
27th Apr 2023, 08:14 PM #62
Most Valued Member
- 5,784
Strange piece of kit, what did it do before it got butchered????
27th Apr 2023, 09:08 PM #63
Most Valued Member
- 4,870
Lived in his junk bin.
27th Apr 2023, 10:20 PM #64
Philomath in training
- 58
- 6,462
Lid of a key safe
28th Apr 2023, 07:57 AM #65
Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,096
Ka-ching!!! You win the prize - a hand full of scrap Alloy:
IMG_4143.jpg IMG_4144.jpg IMG_4145.jpg IMG_4146.jpgNigel, from a cave FULL of unfinished projects and lost tools.
4 bandsaws, 3 drill presses, 2 Hercus 9s, and an AL 3 3 6
(oh, plus an RF30, and an Oliver of Adrian ACE)
2nd Jul 2023, 11:05 AM #66
Golden Member
- Oct 2001
- ACT
- 661
mystery item
Got a batch of things at an auction and got no idea what this one was originally for, so open to ideas.
looks to be an old 'mixer' but for what?
body is made of brass/bronze and has oxidised to green and the three arms I assume fit over a bucket/container
has two set of arms below that turn in opposite directions - side of one missing.
2nd Jul 2023, 12:51 PM #67
Diamond Member
- Aug 2019
- 56
- 1,096
I would guess that is a paint can mixer
2nd Jul 2023, 03:53 PM #68
Most Valued Member
- 5,784
In years gone by, prior to the early50's, I believe, the "paint" that was used was Kalsomine, and what you have is a mixer for it, IIRC. Going by the oxidisation of the brass, makes me think this anyway.
My father was a painter, and I can remember scraping it off the walls on older houses, as a kid, prior to painting with modern paints.
Kalsomine
A thin whitewash composed primarily of Paris white and water. It was sometimes used instead of the more expensive paint to cover walls and fences, and was said to prevent mites when painted on the inside of chicken houses.
1001 Words and Phrases You Never Knew You Didn’t Know by W.R. Runyan Copyright © 2011 by W.R. Runyan
2nd Jul 2023, 05:33 PM #69
Golden Member
- Oct 2001
- ACT
- 661
top bearing point is worn and has had a lot of use.
no paint on the thing what so ever, but if you think thats what it is, i'll take your word for it.
thanks
2nd Jul 2023, 06:23 PM #70
Most Valued Member
- 5,784
Kalsomine was a powder mixed with water to become a paint that was applied to anything that needed to be white. Have seen where hessian was painted to become a divider making one room into two, presumably boys and girls as they got older. Several coats applied, it becomes reasonably thick enough not to see through it.
2nd Jul 2023, 07:35 PM #71
Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
If you need to open any more locks, have a look at the LockPickingLawyer on youtube. He's opened a MASTER Lock one of those, it didn't take long.
JohnQ
2nd Jul 2023, 11:45 PM #72
25th Oct 2023, 08:31 PM #73
Diamond Member
- Aug 2019
- 56
- 1,096
Mystery 13 (#12 was zsteve's mixer thingy)
Found a 40ish mm round chunk in the scrap pile,
threw it in the lathe, turned a step, flipped ends,
drilled a hole, then turned a taper,
Then angle grind a chunk out:
and then clean it up in the mill.
(poor photo - sorry)
What on earth is this for???Nigel, from a cave FULL of unfinished projects and lost tools.
25th Oct 2023, 09:15 PM #74
- 58
- 6,462
Off/ on knob for a magnetic indicator base.
29th Oct 2023, 07:15 PM #75
Diamond Member
- Aug 2019
- 56
- 1,096
...was a chunk of steel, so wouldn't work well in a mag base.
Was an adapter for a valve spring remover:
The red anodised tool is American, meant for big V8 heads.
This engine is a 2L Hyundai. Tiny springs and valve caps, and not much space between them and the head casting walls (overhead cam, small lever cam followers)Nigel, from a cave FULL of unfinished projects and lost tools.
Mystery Car
By Goggomobile in forum AUTO RESTORATIONReplies: 9Last Post: 13th Mar 2016, 01:59 AM -
Mystery item.
By stix012 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 2Last Post: 1st Mar 2016, 06:44 PM -
a mystery Lathe
By thorens in forum METALWORK GENERALReplies: 16Last Post: 27th Feb 2016, 11:05 PM -
mystery tool
By thorens in forum METALWORK GENERALReplies: 14Last Post: 29th Jun 2015, 01:10 AM -
Mystery referral
By zenwood in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 0Last Post: 26th Aug 2005, 05:32 PM
