Results 46 to 60 of 78
Thread: Mystery Project. What is this???
3rd Apr 2022, 09:08 PM #46Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
No guesses - my photos must have been uninteresting.
It is a set of axle seals for a wheel:
The originals were shredded. No locating lip remaining, not flat enough to seal grease in.
3rd Apr 2022, 09:45 PM #47
The plastic wheels on my compressor have oil holes in them ! No grease ! Not that I have ever bothered oiling them.Best Regards:
27th Jun 2022, 12:09 PM #48Diamond Member
- Aug 2019
- 1,196
Mystery 9
Some remediation of some damaged blocks on the surface grinder:
There are about 20 of these things. Mild steel. They have a sliding tapered block for height adjustment. The thing that attaches to them wasn't tightened properly, and has pushed one side of the top surface down.
First time, as a reference I used a thin strap that holds the sliding block in place, but couldn't get it accurate enough. So, for the second attempt, parallel under the sliding block.
Anyone want to guess what they are off?
5th Jul 2022, 08:10 PM #49Golden Member
- Oct 2001
- ACT
- 667
dont know what that is pictured.
though I note how long that last name is stamped on the machinist/toolmakers clamps, hate to have to stamp that all the time (mine is 10 letters which I thought was enough)
22nd Jul 2022, 04:18 PM #50Diamond Member
- Aug 2019
- 1,196
Here are the tings, in-situ:
They set the height of the punch blocks in a large sheet metal bending machine.
8th Dec 2022, 07:09 PM #51Diamond Member
- Aug 2019
- 1,196
Mystery 10
Finishing off someone else's project.
Bandsawing corners off a 16mm steel plate:
then rounding the ends off:
(that plate was heavy, and got HOT. I nearly burnt the latex gloves into my skin!)
all so it clears the lead screw on a Hercus AL10000 lathe:
So, a long plate, bolted onto a faceplate, with a slot and some threaded holes.
What does it do??? What is it for???
8th Dec 2022, 09:10 PM #52Most Valued Member
- Healesville
- 2,129
8th Dec 2022, 09:10 PM #53Most Valued Member
Is it so you can turn a 1/2 scale locomotive wheel???
12th Dec 2022, 05:58 PM #54Diamond Member
- Aug 2019
- 1,196
con-rod machining jig
It is for machining engine con rod bearings on a lathe.
In this case, removing the thin white metal bearing, then boring out the steel, to fit a normal bearing shell.
The slot is to accomodate different lengths of rod; from Austin 7, to Desoto straight 8, and Rolls Royce 6
12th Dec 2022, 06:37 PM #55Most Valued Member
Thanks for the what it is. I'd never have guessed as to what it would be.
3rd Jan 2023, 07:29 PM #56Diamond Member
- Aug 2019
- 1,196
Mystery 11
A 1/4" Whitworth bolt in the lathe. Part off the head, and then grind some flats in it:
and, because this grinding wheel was a little small, file the radius flat:
(I should have used the surface grinder, or the mill, but I always find work holding a challenge.
Round things always just seem to get thrown in the lathe chuck)
So, what will this thing be used for?Nigel, from a cave FULL of unfinished projects and lost tools.
3rd Jan 2023, 10:43 PM #57Most Valued Member
Looks to me to be a type of locking key, giving it a partial turn then prevents the part coming out????
What for, only you know
7th Jan 2023, 10:39 PM #58Diamond Member
- Aug 2019
- 1,196
Kryn is close.
Its a ruler lock from a combination square:
(not that Rabone Chesterman one, which is an M6 thread,
but I didn't take a photo of the repaired item)
The owner broke it once, and welded a blob on the end of a bolt thread, but it didn't last.
He started welding a new blob on:IMG_3799.jpg
but then came to me wondering why the weld broke.
His guess was the weld was too "hard", compared to the bolt.
Hence my creation of a mostly mild steel replacement.
I think the flat on his bolt was too thin.Nigel, from a cave FULL of unfinished projects and lost tools.
7th Jan 2023, 11:15 PM #59Most Valued Member
Thanks for the answer. What threw me was the extended bit past where the rule slot goes. Plus didn't see the rest of the bolt.
I need a few of those myself, if I can find the rest of my squares, I think I have/had about 4 of the 300mm ones and 3 of the 150.
They keep growing legs and disappear into the other shed, never to be seen again.
27th Apr 2023, 07:46 PM #60Diamond Member
- Aug 2019
- 1,196
Mystery 12:
I had just cut it open to deduce how it works, so more of a mystery than a project.Nigel, from a cave FULL of unfinished projects and lost tools.
Mystery Car
By Goggomobile in forum AUTO RESTORATIONReplies: 9Last Post: 13th Mar 2016, 01:59 AM -
Mystery item.
By stix012 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 2Last Post: 1st Mar 2016, 06:44 PM -
a mystery Lathe
By thorens in forum METALWORK GENERALReplies: 16Last Post: 27th Feb 2016, 11:05 PM -
mystery tool
By thorens in forum METALWORK GENERALReplies: 14Last Post: 29th Jun 2015, 01:10 AM -
Mystery referral
By zenwood in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 0Last Post: 26th Aug 2005, 05:32 PM
