Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 78
  1. #31
    Aug 2019
    Revesby - Sydney Australia
    57
    1,196
    Most ingenious answer: hand-pump piston. It certainly is that shape...
    but no, it is much more mundane –
    the holder for a cheap diamond dresser, for a surface grinder.
    The dressing rod was about $3 shipped:
    https://www.aliexpress.com/item/4000340991244.html
    and someone convinced me to have a solid holder - nearly as tall as the rod. I found a slug of cast iron the right size, but it was quite heavy, so I needed to machine some weight off it for safe handling.
    The web page said the diamond should be trailing by 15°, so I made the top slope away at that angle, to help me line up the tangent of the wheel for the trailing position on it.
  2. #32
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    There's no way I would have guessed that and got it right. That's a good idea , basically a good size weight that will stay on the magnetic chuck and hold the diamond dresser to dress the wheel.
    All The Best steran50 Stewart
  3. #33
    Sep 2008
    Riddells Creek, Vic.
    838
    It's hard to see in the photo but is the shank of the diamond tilted to 15 degrees also?
  4. #34
    Aug 2019
    57
    1,196
    Quote Originally Posted by steran50 View Post
    Can't make them too easy
  5. #35
    Aug 2019
    57
    1,196
    Quote Originally Posted by Techo1 View Post
    No. I thought about it, but in the end machining simplicity won out:
  6. #36
    Aug 2019
    57
    1,196
    Default Mystery 6
    Toolmaker neighbour needed some help churning some thingies out.
    He claims to be too busy to set up a CNC programme and machine!
    Load some UHMW (ultra high molecular weight polyethylene) round rods,
    drill out to 9.2mm, and machine a step:
    (It was very hard to turn an accurate OD. A big cut works OK, but a small cut fuses the plastic together, and a tiny cut just pushes the plastic away from the tip and polishes a few thou off. Maybe I should have used HSS?)
    Machine a chamfer, and part off:
    Then turn around in the chuck, and clean up the parted face:
    These little Holman hose thingies fit in them:
    so they have something to do with fluids.
    What are they for?
  7. #37
    May 2011
    Murray Bridge S Aust.
    5,959
    They look like a type of hose clamp, maybe for higher pressures???
  8. #38
    Mar 2011
    Southern Flinders Ranges
    1,555
    They look like Type92 rack insulators.. but I’m going to suggest they are to stop coolant pipes chafing in a housing or something similar
  9. #39
    Jan 2004
    Mackay North Qld
    6,446
    Components for a multi point machine oiling system, maybe.
  10. #40
    Aug 2019
    57
    1,196
    Grahame is sort of close.
    They are fluid transfer hose couplings, for power steering racks:
    I think on these racks, there are 4 hoses. Two pressure hoses that move the ram+rack,
    and two sort of drain/balance hoses, that collect any fluid that leaks past the main seals,
    and balance the air pressure so the dust boots don't blow out.
    I suspect fluid goes back to the reservoir.
    These were just prototypes for testing, before the toolmaker gets around to the CNC job.
  11. #41
    Aug 2019
    57
    1,196
    Default Mystery 7
    I didn't machine these, but they are an interesting shape:
    (the brass things, not the home made spanner, or old mic.)
    Most of the things have a curved chamfer on one side, and the through hole is offset from the middle of the rod and the straight side of the chamfer.
    Anyone want to guess their purpose?
  12. #42
    Oct 2007
    Alexandra Vic
    69
    654
    My guess would be clamping something to something else that is round. Shallow disk is fits into a recess and a bolt passes through it to the longer part with the semicircular cutout, bolt tightens and draws the larger part against something with a matching radius to clamp the two objects together. Obviously, there is a fixture (cast, forged or machined) that completes the system and has a round opening to accommodate the circular material that the unit is clamping to.
    I know it is about as descriptive as the wording in a patent, pure gibberish but the best I can do after midnight without breaking out the CAD and doing a drawing.
  13. #43
    6,477
    Quote Originally Posted by nigelpearson View Post
    Hi Nigel,
    They look like split collets ! Used for clamping something to a round column.
    I use split collets any time that I need to clamp a bracket to a round post. My Norman tool post uses one to clamp the tool holder to the tool post.
  14. #44
    Aug 2019
    57
    1,196
    Baron is sort of close - they are for clamping something round !
    I can't find a photo for the machine they are off, but it is a big old spot welder. They are the electrode clamps.
  15. #45
    Aug 2019
    57
    1,196
    Default Mystery 8
    Grab a mystery plastic(*) disc in the Hercus, to machine a step on one side:
    using an assortment of spacers and a threaded rod through the spindle.
    Then, bore out to the required 5/8":
    and carefully grab on the step, to machine the other side:
    * The shavings came off as light grey, and even the Aluminium cutting carbide left a matt finish. Its almost like glass-filled Nylon, but it doesn't seem that tough.
    I actually made a second one from black Delrin. Much easier to machine than whatever the first one was made out of, and a lovely shiny finish.
    Anyway, what are these for?
    (hint - it is to repair something on a compressor)
  1. Mystery Car
    By Goggomobile in forum AUTO RESTORATION
    Last Post: 13th Mar 2016, 01:59 AM
  2. Mystery item.
    By stix012 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 1st Mar 2016, 06:44 PM
  3. a mystery Lathe
    By thorens in forum METALWORK GENERAL
    Last Post: 27th Feb 2016, 11:05 PM
  4. mystery tool
    Last Post: 29th Jun 2015, 01:10 AM
  5. Mystery referral
    By zenwood in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 26th Aug 2005, 05:32 PM
