Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 78
  1. #16
    Jul 2006
    Athelstone, SA 5076
    4,258
    rustic pot plant stand
  2. #17
    Jul 2021
    Central NSW
    25
    Put bucket on top = oil change stand. But I don’t have a hoist…
  3. #18
    Aug 2019
    Revesby - Sydney Australia
    57
    1,196
    Creative responses. I particularly like the thought of a very tall cow
    It is actually a poor-man's forge:
    I was inspired by this photo from somewhere:
  4. #19
    Mar 2011
    Southern Flinders Ranges
    1,555
    Making rivets?
  5. #20
    Aug 2019
    57
    1,196
    Making rivets?
    That would require an anvil, and real blacksmithing skills, but close.
    Large imitation nail/bolt heads:
    which are for a pub door.
    Seperate thread here: https://metalworkforums.com/f266/t207279-fake-nails
  6. #21
    May 2011
    Murray Bridge S Aust.
    5,959
    Nice idea. Won't SWMBO kill you when she finds out what you are using her hair dryer for?????
  7. #22
    Aug 2019
    57
    1,196
    Default Mystery 4
    What is it?
    no, I'm not turning the Hercus into a giant slitting machine
  8. #23
    May 2011
    5,959
    At first I thought it was a roller for an English wheel, but seeing the last pic it looks like a part for a Battlebot!!!
  9. #24
    Dec 2007
    Sydney
    399
    It will be parted off to be a spacer to adapt the sawblade to fit a smaller shaft on a circ Saw.
    You can buy them at Carbatec, or you could years ago when I worked for them.
    I have quite a few to suit different sizes.
    H.
    Jimcracks for the rich and/or wealthy. (aka GKB '88)
  10. #25
    Aug 2019
    57
    1,196
    ...seeing the last pic it looks like a part for a Battlebot!!!
    My business card does mention killer robots:
    so Kryn might have been on the right track?
    but no, Henry is closer. It doesn't get parted off – actually used as replacement washer:
    or an arbor, so it locates better on the long threaded spindle of this Tanner table saw.
    Here is the original washer, and the blade below has what my Dad used to do; carefully fit a washer and centre-punch it for a tight fit:
  11. #26
    Aug 2019
    57
    1,196
    Default Mystery 5
    A slug of cast iron, some turning and drilling:
    Surface grind the rough side, as a reference for grinding the lathe faced side:
    (looks like my Hercus cross slide is nearly dead on perpendicular?)
    Turn a 75° taper on the rough front, and a groove on the side:
    Then drill a side hole, and a clearance hole, for a grub:
    (looks like my centering indicator is inaccurate?)
    So, finished object. What is it for?
  12. #27
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    I was thinking a pulley first off, but I think it's a former for a bender ?.
    All The Best steran50 Stewart
  13. #28
    6,480
    Happy New Year Nigel, Nice pictures.
    A quick tip for getting a hole dead centre in a round object !
    Use a "V" block in the vise then align the drill in the bottom of the "V". As long as you don't move the vice or the drill, when you sit your work on the "V" block and drill it, it will be perpendicular to the bore.
    Having a vice on an X-Y table helps greatly.
  14. #29
    Mar 2011
    1,555
    Drum for a small capstan winch
  15. #30
    Jul 2011
    Adelaide
    837
    Quote Originally Posted by nigelpearson View Post
    Piston for a hand water powered pump
  1. Mystery Car
    By Goggomobile in forum AUTO RESTORATION
    Last Post: 13th Mar 2016, 01:59 AM
  2. Mystery item.
    By stix012 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 1st Mar 2016, 06:44 PM
  3. a mystery Lathe
    By thorens in forum METALWORK GENERAL
    Last Post: 27th Feb 2016, 11:05 PM
  4. mystery tool
    Last Post: 29th Jun 2015, 01:10 AM
  5. Mystery referral
    By zenwood in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 26th Aug 2005, 05:32 PM
