Results 61 to 71 of 71
30th Sep 2021, 08:10 AM #61Most Valued Member
- 2,672
Thanks John. Hopefully not the same issue here but good to be aware of it.
8th Oct 2021, 09:02 PM #62New Member
- Sep 2020
- 9
DSG Weight
That's a very nice lathe Steve. Any idea roughly how much it would weigh?
Ben.
9th Oct 2021, 12:05 AM #63Most Valued Member
- 2,672
Thanks Ben.
Not exactly sure, but best I can work out it’s between 3500-4000kgs.
16th Oct 2021, 10:07 AM #64Most Valued Member
- 2,672
Got it moved to its final position
I really like the height it’s sitting at from an operators perspective. Just feels “right” - but means I need to find a way of raising it about 100mm off the concrete.
Given that I’m not planning to be turning any large out of balance items on it the best way I can think of is probably some red gum sleepers with steel bearing plates for the leveling bolts to bear on.
Any other thoughts?
16th Oct 2021, 10:12 AM #65Philomath in training
I made some pedestals out of 100 PFC. As long as it is attached to the lathe, there should not be a problem.
16th Oct 2021, 04:12 PM #66Most Valued Member
- 2,672
Thanks Michael.
I’ve got a couple of odd bits of PFC and UB but not enough of a given size to do the whole job.
I’ve decided to go with the sleepers for now as they are easily available from the big green shed. Just need to make up some bearer plates for adjusters.
16th Oct 2021, 05:10 PM #67Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
See how the sleepers go, but i think you may have trouble keeping the lathe leveled with them.
16th Oct 2021, 05:34 PM #68Most Valued Member
- 2,672
Yes, will have to see how it goes in that respect with moisture changes etc.
16th Oct 2021, 11:17 PM #69Most Valued Member
Hi Steve, what lengths of 100mm channel do you think you'll need? Can bring some over when I come to pick up the
Lathemill.
17th Oct 2021, 10:01 PM #70Most Valued Member
- 2,672
Adventures with a jolly green giant
Thanks for the offer Kryn, but looking more closely when I put the sleepers in today the channel probably wouldn’t work for the tailstock and center supports anyway as the adjusters are only on one side of the pedestals.
The headstock has 4 adjusters so channel could work for that but TBH after spending about 3hrs today jacking/packing/screwing/swearing getting it down off the pallet jacks and blocks I’m not in a hurry to repeat the exercise anyway!
I figure if I let the timber dry out and stabilize over summer then seal it up it with something it shouldn’t move too much after that anyway.
The floor is painted so it won’t suck moisture up from the bottom through the concrete.
Will see if reality matches the theory though.
Here’s a picture of the bearing plates. I put a couple of screw holes in each one in case I need them, but I’m not expecting them to move on the timber.
The 16mm plate was some rusty scrap I had lying around. Didn’t see the point in skimming the top to make it look pretty!
The important bit was the recess for the adjuster to locate and bear in.
17th Oct 2021, 11:32 PM #71Most Valued Member
The offers there should you need them.
Adventures in TIG
By skypig in forum WELDINGReplies: 2Last Post: 24th Jul 2021, 04:38 PM -
Adventures with my Klopp shaper
By OxxAndBert in forum METALWORK GENERALReplies: 26Last Post: 6th Oct 2019, 12:30 AM -
giant beer bottle elevator
By Benoit in forum METALWORK PROJECTSReplies: 3Last Post: 11th Dec 2015, 02:22 PM -
Where the Giant left his Coffee Cup
By DSEL74 in forum METALWORK GENERALReplies: 18Last Post: 23rd Jan 2015, 12:57 PM -
Iron Giant
By Woodlee in forum METALWORK GENERALReplies: 7Last Post: 18th Feb 2012, 08:54 PM
