Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 71
  1. #31
    Jul 2016
    35
    1,522
    I've only used one DSG with dual dials and it wasn't mine so small sample size but definitely heavy
  2. #32
    Nov 2017
    Geelong, Australia
    57
    2,665
    In regards to a DRO - do longer lathes typically still use the normal glass scales? I'd need somewhere between 2.5m and 3m long, and I don't like my chances of getting one via Aliexpress etc still in one piece!
  3. #33
    Jul 2016
    35
    1,522
    Your best bet for scales the long is newall. May as well light your wallet on fire though. I would only do the cross slide
  4. #34
    Mar 2014
    South of Adelaide
    1,227
    Both of the big lathes at work use a magnetic tape scale, they are cheaper for longer lengths. I'm pretty sure it is less accurate than a glass scale, but i haven't noticed it, and i regularly need to get shoulders accurate to less than 0.02mm. I will find out what brand ours are.
  5. #35
    Nov 2017
    Geelong, Australia
    57
    2,665
    Thanks Snapa - that would be great.
  6. #36
    Oct 2016
    470
    Thanks!
    Did you notice that the only dial on that lathe that's working correctly is the saddle! The cross slide and compound metric dials don't move.
    Power feed on the compound was a surprise - will have to check that out on mine, but don't think it has it.
    Caskwarrior - I wouldn't have thought they would make much of a difference to the feel if everything in the dials was clean and working properly.
    Interesting if the reality is otherwise.
    Its only a very minor ratio change - 125/127 teeth, so near as dammit the dials are direct coupled. Definitely some close fits though and a lot of surface area inside the dials, so probably wouldn't take much crap buildup to start to bind things up.
    Here's a shot of the inside of the saddle dials. Just a larger version of the cross-slide one.
    Also one of the locking arrangement for zeroing the dials.
    A tapered thumb screw in the end of the shaft pushes some pins out to grip on the inside of the imperial dial bore.
    Yeah i notice. a bit odd maybe something is broken inside those dials
  7. #37
    Dec 2011
    Sydney
    505
    One DRO manufacturer offering magnetic scales is Electronica (electronicaems.com) based in India.
    In the US their products are marketed by Dro Pros, but you can deal with the manufacturer direct.
    I have had been thinking of getting a DRO with magnetic scales because they are compact. Also not easily contaminated by dirt.
    Bill
  8. #38
    Mar 2014
    South of Adelaide
    1,227
    Quote Originally Posted by WCD View Post
    Bill
    Dirt ingress really isn't that much of a problem with glass scales, we have 3 lathes fitted with glass scales at work, and have only had 1 failure in 10 years. we managed to clean the faulty scale and it has given no problems since.
  9. #39
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    760
    Interesting how you go with getting 3 ph connected.
    At the shop outta town am facing a similar dilemma. A fair distance from nearest 3ph pole.
    Supplier tells me my next toy will pull 32Amp for brief periods. Thinking generator possibly with power factor correction - not cheap, but dread to even get a quote from supply company.
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
  10. #40
    Nov 2017
    Geelong, Australia
    57
    2,665
    Can’t see me getting 3ph any time soon unfortunately - unless it gets extended closer to me with the development across the road.
    Knowing my luck, if they do extend it then it will come from the opposite end and not past my place!
    A generator is still an option, but hoping I can get it running reasonably on single phase with the VFD.
    I’ve had the motor and spindle running tonight on the 11kW Ecogoo 220-380v VFD.
    Set the start/stop Accel/decel periods to 6s, left the VFD set at its 11kW motor setting and did an auto tune. Seems to run nicely albeit with more inverter squeal than I’d like.
  11. #41
    jatt's Avatar
    Bendigo
    51
    760
    Not sure what your experience with power supply utilities is?
    Now this is based on my 2 experiences dealing with "upgraded/new" installs. My latest is a 80 amp 3ph underground to replace a single ph overhead (privately owned poles) in town. Biggest I could get at this site without going the transformer route. Wasnt even going to ask what bad boy would cost.
    If you havent simply resigned the idea as being a pipe dream, then this might be worth considering.
    You can get them to do an offer to connect (paperwork excercise outlining details, cost etc..) and put in that a new subdivision is going up close to you.
    Not sure how advanced this development is in real terms, but if the paperwork to put the juice hasnt been set in stone.....
    Anyway enough of my 2 bobs. Time to sit back and watch the trials and tribulations of shoehorning your latest aquisition in.
  12. #42
    Nov 2017
    Geelong, Australia
    57
    2,665
    Default Adventures with a jolly green giant
    Thanks Jatt - I'm hearing you. Spoke to my sparkie mate yesterday, he's dealing with them all the time so is going to put in a request for connection for 50A 3ph and see where it goes from there.
    Been playing around with the 3D printer to make a prototype gear for the dials.
    A couple of iterations later and this is looking pretty good with M0.86 (easy to do in software!), and 20T.
  13. #43
    Mar 2014
    South of Adelaide
    1,227
    That is a pretty odd gear tooth size. you will have hand grind a tool if you want to cut one. 32DP is a common size that is close to what you have printed might be an option to try.
  14. #44
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    I agree with Ash - that is an odd one. As DSG are English and the lathe old rich in experience, I suspect it is more likely to be DP -30DP is M0.85 (for comparison, 32DP is M0.79).
  15. #45
    Nov 2017
    Geelong, Australia
    57
    2,665
    Thanks guys. From measuring the closest I came up with was 30DP, but as a single piece gear that was too loose in the 3/4” bore.
    I just tweaked it up FreeCAD until it was a nice fit in the bore.
    The printed one actually works really well, but I guess isn’t likely to last - particularly out of PLA+.
    Thinking about a making a metal one I’d probably make it from 3 pieces - a central shouldered shaft and a gear at each end.
    They way it’s a solid bit in the bore so should wear more slowly than with the center toothed section in the bore like my printed one.
  1. Adventures in TIG
    By skypig in forum WELDING
    Last Post: 24th Jul 2021, 04:38 PM
  2. Adventures with my Klopp shaper
    By OxxAndBert in forum METALWORK GENERAL
    Last Post: 6th Oct 2019, 12:30 AM
  3. giant beer bottle elevator
    By Benoit in forum METALWORK PROJECTS
    Last Post: 11th Dec 2015, 02:22 PM
  4. Where the Giant left his Coffee Cup
    Last Post: 23rd Jan 2015, 12:57 PM
  5. Iron Giant
    By Woodlee in forum METALWORK GENERAL
    Last Post: 18th Feb 2012, 08:54 PM
