Results 1 to 13 of 13
Thread: Large diameter fly cutter
24th Jul 2021, 09:21 PM #1Member
- Nov 2019
- AU
- 52
Having a crack a making a larger diameter fly cutter
I didn't have a end mill long enough to reach the bottom of the pocket so I pilot holed the carbide seat then flat bottom ground a drill bit to bore the seat.
Sent from my CPH1921 using Tapatalk
24th Jul 2021, 09:23 PM #2Member
- Nov 2019
- AU
- 52
Making the arbor adapter from an old tractor engine gudgeon pin
24th Jul 2021, 10:57 PM #3Most Valued Member
How hard was it to machine the Gudgeon Pin? Have been told that they are very hard on the outer casing. What tooling did you use HSS or Carbide?
Thanks,
24th Jul 2021, 11:00 PM #4Member
- Nov 2019
- AU
- 52
Way harder than I expected to cut through the hard casing. Killed one corner on my cnmg carbide just cutting through the outer layer.
25th Jul 2021, 12:43 AM #5Most Valued Member
How will you mount it to the flywheel??? I think if it was welded to it, it could be a real problem.
25th Jul 2021, 04:54 PM #6
Hi Ajax, Guys,
I'm watching this thread with interest !
This is a picture of my "Go To" fly cutter.
Not quite as big as yoursBest Regards:
25th Jul 2021, 07:58 PM #7Member
- Nov 2019
- AU
- 52
I'm making a spigot out of that gudgeon pin to make up the difference between the ID of the flywheel (41.85) to my iso40 arbor who's OD on the spigot is 22mm. That spigot will be a press fit and I'm intending to use 2 m8 Allen head bolts as drive tags. The center bolt of the arbor with a large washer will clamp the 2 together...
..... probably going to be some epoxy involved in that last step.
25th Jul 2021, 08:00 PM #8Member
- Nov 2019
- AU
- 52
30th Jul 2021, 09:35 AM #9Member
- Nov 2019
- AU
- 52
Hmmmmmm there will be a delay to this project for many weeks. I may start another thread on the reason as to why.
It's shed safety related
30th Jul 2021, 10:21 AM #10Most Valued Member
- 2,669
Doesn’t sound good - hope it’s not you that’s damaged.
30th Jul 2021, 03:27 PM #11Member
- Nov 2019
- AU
- 52
Deleted
30th Jul 2021, 07:12 PM #12
Hi Ajax,
I do hope that that you recover quickly !
Oxygen bottles due to the extremely high pressure that they contain can do a lot of damage if they are not treated with care. I recall some years ago an oxy bottle on its side screaming down the yard and burying itself into a brick retaining wall when the delivery driver bounced the cylinder off the lorry knocking the valve neck and it breaking off ! Luckily no one was injured. Though I reckon at least one guy got brown undies . We never recovered the valve.Best Regards:
30th Jul 2021, 08:00 PM #13Member
- Nov 2019
- AU
- 52
Reckon I got a pair of undies to match lol
Suitable Sheave Diameter
By Oldneweng in forum METALWORK GENERALReplies: 2Last Post: 17th Oct 2017, 12:12 AM -
Major Diameter Help for threading with a Die
By ventureoverland in forum METALWORK GENERALReplies: 19Last Post: 17th Nov 2016, 10:59 AM -
Diameter Of A Circle
By Keith_W in forum METALWORK GENERALReplies: 56Last Post: 27th May 2014, 03:51 PM -
Home made large diameter fixed steady
By nearnexus in forum METALWORK GENERALReplies: 21Last Post: 5th May 2013, 08:59 PM -
minor diameter
By tanii51 in forum THE HERCUS AREAReplies: 1Last Post: 26th May 2010, 10:55 PM
