Results 1 to 4 of 4
6th Jun 2021, 11:32 PM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
Magnetic base clamp in sixteen steps
The toolmaker took back his Mercer mag-base, that looked a bit like this:
For a while I tried to cope with a smaller/weaker base,
but after it fell off something and bent my large plunge indicator, it was time to build a better setup.
I was given a fine adjustment spring rod thingy a few weeks ago,
so I just need a good mounting system. Rummaging around,
I found 50mm generic base with a broken hydraulic arm.
1. Unscrewed broken arm, its an 8mm thread.
Grabbed some scrap rod,
machined a ~7.9mm step on the end,
and used crappy 8mm die to cut the thread2. Screwed it into the base, then spent way too long,
trying to cobble together a clamp from available junk.
Decided I would machine a twin disc swivel clamp.
Find some cleanish 50mm round, face in lathe:IMG_1522.jpg 3. Drill through at 11/64,
and started 1/4"WW thread:
(to match my box of cheap old screw handles)IMG_1523.jpg 4. Grab in the mill, load 10mm end mill,
and machine some flats for accurate drilling:
(Spring rod is 8.5mm diameter.
and scrap rod ~9.5mm diameter.
I sort of just eyeballed slot offsets)IMG_1524.jpg IMG_1525.jpg 5. Spot drill:
(actually a lathe centre drill,
because I don't have any real spot drills,
but is conveniently 10mm diameter,
so no collet change required ! )IMG_1526.jpg 6. Drill both thru at 8.5mm: IMG_1527.jpg 7. Enlarge one to 9.5mm:
Made some colourful swarf !IMG_1528.jpg IMG_1529.jpg 8. Back into the lathe for parting off.
First, rotate/align parting tool to the job:
(which is hard against the chuck face)IMG_1530.jpg 9. Then, use side of tool for aligning job in chuck:
(my chuck is bad,
and this saves me dial indicatoring)IMG_1531.jpg 10. Part off between discs. This didn't go well.
There wasn't quite enough space between the holes,
so it was an interrupted cut, which killed my insert.
Finished off with hacksaw:IMG_1540.jpg IMG_1549.jpg 11. Face off, and check the rod still fits:
(I was worried the lathe might have
pushed the material in at the edges)IMG_1550.jpg 12. Load the other disc in the chuck:
Using two parallel-ish rods as spacersIMG_1551.jpg 13. Face this one off:
On this one, I barely cut into the holeIMG_1558.jpg 14. De-burrrr:
(and then I filed the edges also)IMG_1560.jpg 15. Finish up the thread.
Mag base and rod comes in handy:IMG_1562.jpg 16. Drill other disc thru at 1/4",
find a washer for the knob,
and assemble!IMG_1563.jpg ... However, one side's disc was machined too thin,
which means the gap between discs was too big,
and the thing doesn't grip due to twisting, so...by too thin,
I mean the rod sat too far above surface16+1.
I need a spacer/washer.
Went looking for copper,
which I thought would be grippier,
but could only find some 2mm brass sheet:IMG_1564.jpg 16+2.
Make it round-ish:IMG_1565.jpg 16+3.
Use round file to make a groove
in the disc where the rod sits,
and assemble again:IMG_1566.jpg
So, I now have a base, with two rods for some positioning, but I need to attach the DI.
Go searching again, and find one old Mitutoyo swivel clamp.
One hole grabs the 8.5mm rod OK, but the other won't grab the 8mm end of my Mitu'o DI???
Some quick boring of a little aluminium tube, and viola.
Here it is, across the rear Vs of my Hercus, showing chuck's 0.15mm run out:
7th Jun 2021, 01:15 AM #2
Hi Nigel,
Did you ever see the thread that I did on my dial indicator for the lathe ? I use mine for all sorts of setting up including stuff in the four jaw.
I simply grip it in the tool post, set at centre height of course. The aluminium strip is bent so that it doesn't quite push on the dial gauge plunger when relaxed. I have another without the aluminium strip for use when working further away from the chuck jaws.
HTHBest Regards:
7th Jun 2021, 08:48 AM #3Diamond Member
- Aug 2019
- 1,196
Yes (and thanks for the reminder).
1) I love the "lever" aspect of that one, that takes the DI away from the chuck.
If I ever setup for milling QCT holders,
I will make a quick change version of that.
Sort of like this, but with your lever/pivot idea:
2) I think your holder gets clamped in like a boring bar?
Which is good to keep out of the way if you are tapping down to centre something,
but means you have to keep turning the chuck back 90° to drift/hammer down?
My ideal would be something that levered underneath the job.
Both away from the drift, and still in the vertical axis without turning the chuck!
...but for now, I have a DI stand that shouldn't fall over too much,
and can reach the chuck from the rear Vs of the Hercus.
(hope it doesn't magnetise the bed )
7th Jun 2021, 05:01 PM #4
Hi Nigel, Guys,
I find that clamping the gauge in the tool post very convenient ! I have an expensive "Noga" that I think only came out of its box once when I got it, since then its been sat in a cupboard unused.Best Regards:
KANT-TWIST Round Handle Clamp 3/4", Clamp Mfg 396
By DSEL74 in forum METALWORK GENERALReplies: 7Last Post: 10th Aug 2019, 08:05 AM -
Eclipse magnetic base info
By kenny_10 in forum METALWORK GENERALReplies: 2Last Post: 25th Jul 2018, 09:07 PM -
Magnetic Base Problem
By grunto in forum METALWORK GENERALReplies: 8Last Post: 13th Nov 2016, 02:42 AM -
VICTORIA Dial Gauge and Magnetic Base
By Peter36 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 5th Oct 2012, 11:10 AM -
Flexible magnetic base
By morrisman in forum METALWORK GENERALReplies: 17Last Post: 22nd Aug 2012, 12:05 AM
