Results 1 to 6 of 6
Thread: AL 320 tail stock movement
26th Feb 2021, 09:23 PM #1Novice
- Dec 2011
- Wodonga
- 10
I have had my AL320 for about 10 years and have managed to do some quite precise and close tolerance work on it. I am happy with the machine although I think making it with a double v bed would take it to the next level. Has any one managed to make the tail stock a tighter fit. It locks down ok but I still get some movement out of it particularly when using larger drill bits. Am I being too fussy or does anyone else have this issue
26th Feb 2021, 11:35 PM #2Most Valued Member
- 4,890
Is the plate that locks it to the bed machined on its clamping face?
Is the underside of the bed where the clamp plate would run , a machined surface?
Can you adjust the clamp so as to apply more pressure to the Tailstock lock?
16th Mar 2021, 08:57 PM #3Novice
- May 2018
- Tea Tree Gully
- 17
14th Apr 2021, 09:34 PM #4Member
- Feb 2021
- Australia Brisbane Qld
- 51
I have same lathe and I struggle too. It drives me nuts
14th Apr 2021, 09:54 PM #5
I think Pipeclay hit the nail on the head ! If those surfaces are not flat and parallel to each other then you only get point contact.
Some time ago I flycut a clamp plate for a lathe tailstock, it was a bit like a banana with a hump in the middle. Whilst it helped the single bolt hole with the pressure from the clamp caused it to bow again. It was replaced with a piece of 12 mm plate skimmed flat. There was enough bolt length to replace the original plate with the 12 mm one.Best Regards:
14th Apr 2021, 10:37 PM #6Member
- Feb 2021
- 51
I have time tomorrow morning I might have a closer look at the situation and investigate further... it would be so good to get it sorted
lathe tail stock
By China in forum WANTED TO BUYReplies: 8Last Post: 15th Jun 2019, 02:11 AM -
Tail Stock Alignment.
By wm460 in forum METALWORK GENERALReplies: 28Last Post: 2nd Feb 2015, 12:20 PM -
Tail stock trouble.
By cookie48 in forum METALWORK GENERALReplies: 10Last Post: 25th Apr 2012, 03:40 PM -
Separating tail stock
By ausdag in forum THE HERCUS AREAReplies: 2Last Post: 10th Oct 2009, 07:00 PM -
Tail stock centre size Help
By dude09 in forum THE HERCUS AREAReplies: 8Last Post: 19th Feb 2009, 09:01 AM
