Results 1 to 7 of 7
Thread: Cugir FU 36 Milling Machine
22nd Jan 2021, 11:02 PM #1Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
G'day
Is anybody familiar with the Cugir FU 36 mill? one might follow me home soon, it appears to be in reasonable mechanical condition, electrically unknown but I can get the sparky at work to look it over for me, It's going to be a bit of a project to get it operational again as it has sat unused for years and has now been out in the weather since Xmas.
So basically, I want you to tell me they're great and to buy it
How do you guys run your 3 phase mills in single phase sheds, switch out motors, VFD's, rotary converters? What's the most economical way to go about it?
Ben
22nd Jan 2021, 11:16 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
That thing is big. Id want to know what the spindle motor draw is because you'll definitely struggle to run that off 10 or 15amp single phase I would think. But maybe you are lucky and its only 4kw.
My mill is smaller but the same era and it has a lot of interlocks and relay logic going on as well as multiple two speed motors. I have 3 phase but if I didn't an RPC or phase changer would be the only option. Id lose too much functionality with a VFD.
23rd Jan 2021, 12:46 AM #3Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
23rd Jan 2021, 01:46 AM #4Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
23rd Jan 2021, 09:17 AM #5Most Valued Member
- Jul 2016
- 35
- 1,522
Does it have its powered overarm amd vertical head?
23rd Jan 2021, 06:07 PM #6Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
23rd Jan 2021, 07:27 PM #7Most Valued Member
- Healesville
- 2,129
That looks like a fun toy Ned
3 phase is the way to go but if you have problems with getting it hooked up or it is the price of a gold mine VFD's could be the way to go.
Assuming it has 3 feed motors on the 3 axis' and a 4 - 5kw motor then a 20 amp 240 circuit would probably run it, maybe not under full load tho with a feed motor working also.
Using 220 - 380 volt VFD's, 3 for the feed motors and 1 for the spindle motor would cost 600 - 700 $ from china.
If the motors can be wired to 240 3 ph then it will be a bit cheaper than that....
Milling machine
By lamestllama in forum METALWORK GENERALReplies: 27Last Post: 21st Jun 2019, 06:02 PM -
Milling machine set ups.
By 4-6-4 in forum METALWORK GENERALReplies: 3Last Post: 1st May 2012, 03:04 PM -
HM 50 milling machine
By woodfast in forum METALWORK GENERALReplies: 3Last Post: 19th Apr 2012, 07:12 PM -
Used Milling Machine
By woodfast in forum METALWORK GENERALReplies: 4Last Post: 15th Apr 2012, 10:07 PM -
A little help with my first milling machine
By festy_ in forum METALWORK GENERALReplies: 36Last Post: 13th Apr 2011, 11:34 PM
