Results 1 to 4 of 4
Thread: Simple Lathe feet
30th Dec 2020, 08:39 PM #1Most Valued Member
- 2,668
Simple Lathe feet
My lathe has felt a bit short since I put the new concrete in the old part of the workshop. It raised the old floor level by about 50mm.
Turned up some feet/raisers from some old hydraulic rod.
I was concerned they might wander in the concrete so cut a recess in the base and made some rubber pads out of insertion rubber. They protrude about 1mm from the steel.
Made a big wad punch out of a bit of pipe and used the press to do the work of cutting them.
And installed.
31st Dec 2020, 06:31 AM #2
Careful Steve, you’re going to wear that nice new press out if you keep using it
Seriously though, nicely done !Best Regards:
31st Dec 2020, 10:50 AM #3Most Valued Member
- 2,668
Thanks John.
If I wear the press out any time soon I'll be having a serious discussion with the manufacturer......
31st Dec 2020, 08:33 PM #4Most Valued Member
Watch out that you don't loose the serious discussion!!!
New Lathe - Feet or not?
By RustyArc in forum METALWORK GENERALReplies: 15Last Post: 24th Dec 2018, 06:49 AM -
'Simple Indexer' for the lathe.
By Steamwhisperer in forum METALWORK PROJECTSReplies: 9Last Post: 19th Jul 2018, 09:12 AM -
So you need a simple slot in steel and you just have a metal lathe.
By aametalmaster in forum METALWORK GENERALReplies: 6Last Post: 1st Apr 2014, 09:18 AM -
Jacked Feet or Shims to level a lathe ?
By steamingbill in forum METALWORK GENERALReplies: 16Last Post: 30th Sep 2013, 09:53 AM -
Lathe/mill adjustable feet pictures
By Dave J in forum METALWORK GENERALReplies: 6Last Post: 30th Mar 2010, 11:02 PM
