Results 1 to 7 of 7
Thread: AL 320 power cross slide feed
16th Dec 2020, 08:46 AM #1Novice
- May 2018
- Tea Tree Gully
- 17
Hi brains-trust, I have recently purchased an AL 320 and have noted in other places on this forum that the lever that controls the cross slide power feed/longitudinal power feed option is not the best design. I have seen that some people have installed a post to stop the lever accidentally being thrown too far, and thus changing cross to longitudinal (or vise versa) and wrecking the part. Are there any other suggestions to alleviate this issue? (Yes I have experienced this while practicing). Those who have made the mod, any hints? So far, I've been happy with the machine's capabilities, I'm only a learner, so I trust this machine will last me out. It does suffer from the Chinese finish quality, but a bit of cleaning, tinkering and adjusting seems to have worked.
Thanks,
Gary
18th Dec 2020, 06:08 PM #2Senior Member
- Nov 2019
- Brisbane
- 69
- 452
AL320 feed lever
Hello from BC.
I had the same problem. The lever and shaft were drilled so far out of lineup the roll pin only went thru one side of the lever. from new the hole was wallered. I took to stopping the feed at the gearbox end and then with the saddle lever. If you try a heavy power feed the selector lever will drop out, maybe.
BC
20th Dec 2020, 09:27 AM #3Novice
- May 2018
- Tea Tree Gully
- 17
16th Jan 2021, 05:42 PM #4Novice
- Dec 2011
- Wodonga
- 10
I have the same lathe and early on had this problem a couple of times. Had it for 10 years now and must have just got used it as I can’t remember the last time it happened. I am going to replace the plastic handles with alloy ones and I will make the carriage/ cross slide control a bit longer to give it a bit more feel. I think because it is so short it is easy to over do it.
16th Jan 2021, 08:18 PM #5Novice
- May 2018
- Tea Tree Gully
- 17
16th Jan 2021, 09:31 PM #6New Member
- Nov 2020
- Brisbane
- 3
AL 320 crossfeed/longfeed lever
I have the AL 320 and I have (initially) experienced pushing the crossfeed lever and then getting long feed. (Easy to do). I found the neutral position then drilled a couple of 3mm dia x 6mm deep holes and inserted pins to stop the over movement. I take one pin out when I want power cross feed and then insert it again and take the other pin out when I want long feed. Works for me.
17th Jan 2021, 01:20 PM #7Novice
- Dec 2011
- Wodonga
- 10
Only issues I have had in the past 10 years was a cooked start capacitor on the drive motor, pretty cheap and easy fix, and I have found when drilling larger holes go up in small increments as the tail stock can move a bit. Other than that happy with the machine, it is what it is, probably not the most refined small Chinese lathe but a good over the bed capacity and the 38mm through the head stock is really handy too. Over all I have been happy with the machine. I recently had the run capacitor go on the mill, same age as the lathe, $16 at JCAR and ten minutes work good to go. Now I am not moving constantly any more I may look at getting some better machines but for time being they are producing the results I am happy with.
Wringing cross slide?
By Malibu in forum THE HERCUS AREAReplies: 11Last Post: 12th Nov 2019, 01:44 PM -
Engaging power longitudinal/cross feed on Al960 and similar
By Hornetb in forum METALWORK GENERALReplies: 5Last Post: 5th Aug 2016, 05:49 PM -
Cross slide scraping
By Stustoys in forum METALWORK GENERALReplies: 358Last Post: 13th Jan 2013, 10:08 PM -
Cross-slide play
By jack620 in forum METALWORK GENERALReplies: 23Last Post: 19th May 2012, 07:50 AM -
Cross Slide Nut
By raypat in forum METALWORK GENERALReplies: 19Last Post: 9th Dec 2011, 01:41 AM
