Results 1 to 12 of 12
Thread: Knobs like Bob's
14th Nov 2020, 06:03 PM #1Philomath in training
- 6,563
Knobs like Bob's
Over here (https://metalworkforums.com/f65/t205892-hunt-handle), Bob is looking for a handle for his saw. I suggested in that thread that machining one was possible and this morning decided to put my money where my mouth was.
There were two methods I was considering. One used my Volstro head. There, I mounted the stock on the dividing head (to get the 6 places), offset the cutter half the ridge width and then radiused the end
The result was not bad, but the set up seemed a bit insecure. This is a knob after doming the front and parting the stock off. The second photo shows my insufficient efforts to clean up between the ridges with a file. If I was doing this for real, I'd make up a filing template so I could check the profile. Here I just thought 'that's close enough to prove it works' and left it at that. Probably the area around the spheres needs some attention with rifflers to blend, but again, not a big problem.
The second method used a collet block mounted on a rotary table so that the axis of the end of the ridge was the same as the RT axis. A 1-2-3 block was used as a stop for repeatability. I liked this method more as it was very straight forward. The only problem here is alignment. Getting the collet block aligned with the table X axis proved in hindsight to be the biggest problem. I thought I had it down pat, but if you look carefully at the last photo, the ridges are not quite square. I'm out by 3 degrees . I'll pass it off as a user not knowing their own strength and over torquing when tightening it up.
However, it can be done. The R/T method is probably the best, although both produce a result - or would if properly set up . Bob's big concern was the spherical ends not being cut properly, but I was surprised how well they did come out.
14th Nov 2020, 06:43 PM #2Member: Blue and white apron brigade
As we used to say in second year high school "skill plus plus"!
14th Nov 2020, 08:18 PM #3.
- 6,459
Pretty flash Michael! Had I known you were going to get stuck into it I would have provided a working drawing!!
Turns out I require yet another knob, the plastic gear looking things are ring ins,
14th Nov 2020, 11:32 PM #4China
- Dec 2005
- South Australia
- 1,658
Plus one for trickery!!
29th Nov 2020, 12:44 PM #5Most Valued Member
Nice knob Michael!
Is that a router bit in your collet?
If so, I didn't even know that was a thing you could do!
29th Nov 2020, 12:57 PM #6Philomath in training
- 6,563
Sure is Simon. Carbide router bits work very nicely for Aluminium in particular. You'd ruin it if you tried this with steel I suspect, but for softer metals (CI, Al, etc) it works. In this particular case because a specific radius was required, the easiest way to get that was to head to Carbatec and buy a router bit to suit.
You can also use them in the lathe as form tools if needed.
29th Nov 2020, 01:03 PM #7Most Valued Member
Oh boy. A whole new old has just opened up to me!
I got to try that. I assume the usual carbide on Al cutting speeds apply?
29th Nov 2020, 05:48 PM #8Philomath in training
- 6,563
If you can get it that fast...
(but yes)
30th Nov 2020, 02:36 PM #9.
- 6,459
They don't have to always spin Simon...https://metalworkforums.com/attachme...4&d=1509928900
30th Nov 2020, 04:50 PM #10Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
Just quietly, they don’t have to be TCT either, the HSS ones work too.. and both with also work on mild steels with some degree of success (not as well as a purpose made milling cutter, but it can be done).
1st Dec 2020, 01:52 AM #11
Its surprising just how well they do work ! I've used mine on steel as well as other materials. I've even used one to drill a 45 mm diameter hole in 6 mm alloy plate, only because the router bit happened to be the right size and I couldn't be bothered to dig out the boring head.Best Regards:
3rd Dec 2020, 06:58 PM #12Most Valued Member
Thanks guys. Interesting!
So many ways to skin a cat.
Loose knobs n shafts.
By DSEL74 in forum METALWORK GENERALReplies: 36Last Post: 12th Sep 2017, 11:35 AM -
Knobs made from Cabinet Handles
By rodm in forum METALWORK GENERALReplies: 8Last Post: 7th Oct 2012, 04:03 PM -
More Knobs
By toolman49 in forum METALWORK GENERALReplies: 5Last Post: 6th Oct 2012, 12:40 AM -
What's a good material for making round knobs?
By Graziano in forum METALWORK GENERALReplies: 34Last Post: 3rd Jul 2012, 06:23 PM -
Wooden door knobs?
By neksmerj in forum METALWORK GENERALReplies: 2Last Post: 25th Apr 2012, 07:04 PM
