Results 1 to 8 of 8
    Nov 2019
    AU
    52
    Default Chinese toys, they don't make toys like they used to
    So my five year old came to me on Friday and said his little ride on car stopped. I thought oh yeah another one of those cheap scate motors has failed.
    Walked around corner and saw the ref wheel had folded out and underneath. I said something similar to "ah crap".
    This is what I found
    Sent from my SM-A705YN using Tapatalk
    Nov 2019
    AU
    52
    The front axle with the king pins welded in it was made from the thinest box section I have ever seen and the king pin tore clean out of the end of it.
    The box section was 20mm x 20mm which I didn't have any laying around so I dug through the scrap pile and found some 6mm flat bar. At first I didn't consider it as been useful for this project but then an idea struck.
    Made a couple of decent thickness king pin housing and a scissor action axle
    Nov 2019
    AU
    52
    Completed parts ready for assembly
    Axle fitted back under car. Now has a bit of articulation in the front end
    The welds in the steering rod are from a wheel alignment by fire. Cut it into 3 sections and welded them back together over lapping.
    Oct 2004
    Melbourne, Australia.
    51
    Rather ironic in that there appears to be some product placement in the images, namely the G clamp with the word CHINA clearly visible on it.
    By the way, nice repair.
    Mick.
    Nov 2019
    AU
    52
    Hahaha yeah.
    Testing a problem with the controller I accidentally let the smoke out of it. I now realise this this switches it's earths not power as I had assumed. Either way the problem went up in smoke with the controller. Onto plan B .......... that is as soon as I work out a plan B.
    Ordered a frequency controller and some other bits so I see if I can let the magic smoke out of those when they arrive
    Sep 2009
    Newcastle
    341
    Do you mean switches the neutral?
    Switching earth/ground would not actually switch power off at all just make it dangerous if there was a short.
    Nov 2019
    AU
    52
    Its a 12v DC system. Switches the negative might be better terminology.
    Once I get the smoke stuffed back in it I'll post some pics
    Sep 2009
    Newcastle
    341
    Ah, sorry I just assumed AC.
  1. small toys
    By wheelinround in forum METALWORK GENERAL
    Last Post: 27th Oct 2014, 01:47 PM
  2. Never enough toys ...
    By Legion in forum WELDING
    Last Post: 2nd Oct 2014, 12:30 PM
  3. New school,new toys
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 29th Aug 2009, 10:18 PM
  4. Where are all the toys makers
    By colbra in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 12th Jul 2008, 01:45 AM
