Results 31 to 40 of 40
5th Sep 2020, 02:25 PM #31I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
Mine is 20mm wide by 25mm long by 2mm thick. But I'm pretty sure there are different widths, I think the 25mm wide scraper comes with a 25mm wide insert, and I imagine the 30mm wide probably comes with a 30mm wide insert. Not sure if the lengths change. The way the pocket is on the Sandvik, it probably doesn't matter, I think I can run any of the inserts, or flip my insert 90 degrees.
You'll want some way of sharpening it too, if you've seen Stefans video on making a slow speed grinder (Glendo style), that seems the best way to go to me, and useful for other things. I've made the backing plate part out of a slice of a large round of ally I grabbed at the scrap yard about 8 years ago thinking it would be useful (finally was!) I bought a 4 pack of 150mm diamond discs of eBay for about $20. Think they were 320, 600, 800 and 3000. At this stage, I just run the backing plate on a quick and dirty mount in the collet chuck at 270rpm, although I want to find a suitable motor and build it proper with a work table, as I think it'll be very handy, and allow me to do fancy things with my lathe/mill inserts. The 3000 disc is showing a bit of wear, possibly missing a few diamonds, probably a combination of not using a toolrest, thus occasionally bouncing it a bit, and reprofiling with it when I should really have changed over to a coarser disc. The 320 seems to move material pretty quick, but I also bought an 80, which looks aggressive as hell. Haven't tried it yet, came from Dandenong via NSW over the course of 3 weeks, so by the time it arrived...
5th Sep 2020, 08:07 PM #32Member
- Sep 2010
- Port Sorell, Tasmania
- 74
Thanks J&H, have seen carbide flat bar on ebay including 20 *2 *200mm for $30. Claimed to be Chinese YG8 grade which is supposedly roughly equivalent to Sandvik H10. Ill order some and see how it goes.
https://www.federalcarbide.com/tungs...son_chart.html
As far as sharpening goes I have already convinced myself that I need one of Stefans slow speed honing/grinding machines. There are any number of variable speed, reversing electric motors on aliexpress for around $50. I wouldn't think the motor would need to be very powerful. I have other grinding machines capable of heavy cuts.
5th Sep 2020, 09:05 PM #33I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
5th Sep 2020, 09:27 PM #34Member
- Sep 2010
- 74
This is one example, not sure if it is the best. Im guessing that it would be strong enough. 24V, 470 rpm variable speed 3.4 kg.cm torque, $70 inc postage
https://www.aliexpress.com/item/3277...643&fromDetail
8th Sep 2020, 07:21 PM #35Most Valued Member
- Australia east coast
- 2,713
If you do make it down here you're welcome to come & visit, I'm south of Hobart. I'm not interested in a course and have all my own gear including a Biax and 1200 x 900 plate but it's always good to meet someone else into this sort of caper. Couple other local to me interested as well, with their own gear and hands-on practice.
Hell will freeze over before I have *anything* to do with Facebook though.
PDW
14th Sep 2020, 06:29 PM #36Senior Member
- Jul 2017
- Burleigh heads QLD
- 29
- 114
That would be great, I have to admit that we actually used to have en email list to organize meetups but most of the guys had facebook so it took over due to convenience. I think in that changeover we inadvertently excluded a lot of guys in that email list, I actually had one fellow email me recently checking up on things.
22nd Sep 2020, 06:02 PM #37I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
A quick little update - when I ran into the issue of my stone not fitting into the dovetails, I dug around on Practical Machinist and found that Richard King recommended a particular stone as his favourite, and linked to MSC. I tracked down the Norton part number at, of all places, RS Online. Now previously I've steered well clear of RS, but lately they seem to keep having what I want at a competitive price. Case in point, they sell this particular Norton stone at $26 including GST, and free shipping. MSC's price for the stone (although they're not overly cheap in the US either) works out to $22AUD. Not bad, considering that my stone shipped from the UK of all places - must have cost them almost as much in shipping as what I paid!
https://au.rs-online.com/web/p/sharp...d%22%3Atrue%7D
I was a bit put off by the picture of the white stone, but decided to trust the part number, and indeed what I received today was the correct brown MS24 stone.
So if someone is gathering tools for scraping, this would be an excellent thing to grab, would have made life much easier when I was doing all the fiddly dovetail work.
26th Sep 2020, 10:04 AM #38Most Valued Member
Hi J&H,
Maybe a silly question, wrt this stone is that so you can de-bur the dovetails after a scraping cycle?
26th Sep 2020, 02:47 PM #39I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
Yes, it's for deburring after scraping cycles generally, but being rather thin means it's good for getting into the awkward spots. I believe that this is the stone that Richard King hands out to students at his scraping classes - or as least was at some point, he may have found something new and improved by now.
9th Mar 2021, 10:02 PM #40Senior Member
- Sep 2009
- Newcastle
- 342
Very belated reply....
Weight is ~300kg.
The answer is with difficulty.
The difficulty started with the plate getting delivered late one evening by lift gate. I have a long narrow driveway with a grass strip down the middle. So I had built a dolly in preparation, by adding wheels to a pallet. Proceed to have one wheel catch on an expansion joint and end up with pallet / 300kg rock tilted with one wheel buried in grass strip. Now 9pm and raining.
Fortunately old school works -> car jacks and 2x4s -> managed to get a sheet of MDF under the pallet. Then was able to get wooden dowels under the MDF and then (with a lot of huffing and puffing) was able to drag it down the driveway, moving the dowels from the back to the front ad nauseam. Got it into the shed.
Then the granite will sit quietly in shame in the middle of the shed right the in the way for some weeks...
Then getting it from pallet to stand:
It came boxed up in soft plywood. Easy to remove the surrounds. But the plate was sitting on a flat bit of plywood exactly the size of the bottom of the plate. I ended up driving in wooden wedges which lifted the plate enough to get slings underneath. Then a cheap chain hoist from the big beam in the shed and the plate was airborne.
Micro Petrol Air Compressor "Project Loan Out"
By gazza2009au in forum METALWORK PROJECTSReplies: 58Last Post: 28th Sep 2019, 09:20 PM -
First scraping project
By OxxAndBert in forum METALWORK GENERALReplies: 10Last Post: 8th Jan 2018, 02:30 PM -
Hand Scraping a Hand Plane to .0001" Accuracy
By Ulma Doctor in forum METALWORK GENERALReplies: 4Last Post: 28th Feb 2015, 06:38 PM -
New Scraping Project
By scottyd in forum METALWORK GENERALReplies: 11Last Post: 21st Oct 2014, 11:29 PM -
Swiss Scraping or scraping from the shoulder
By Ueee in forum METALWORK GENERALReplies: 3Last Post: 30th Jul 2012, 01:31 AM
