Results 1 to 8 of 8
Thread: Machinery Skate Bearings
27th Aug 2020, 12:50 PM #1Golden Member
- Apr 2019
- 596
Looking to make some machinery skates to move some machines that are arriving soon (hopefully these won't fall off the forklift!!!).
What type of bearing should I be looking to use on the top to allow the skate to swivel under the machine? I have looked at thrust bearings and they tend to be flat bearings with either balls of rollers between 2 separate washer looking bits. There are also the bearings that are used in a clutch as the thrust/release bearing which are larger and seem to be ball type only.
I am looking to have each skate handle 1,000kg (maybe a little more). An ID of 12-30mm and OD of up to 90mm would fit - I am designing around the bearings although the C-channel I will use is 100mm wide.
Rather than looking at the SKF catalogues and not really knowing what I am doing I thought I would ask the brains trust!!
PS - using pallet jack front rollers as the wheels
27th Aug 2020, 03:18 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
Last homemade set I saw was done with tapered roller bearings on the top (trailer bearings most likely because they were cheap). The top of the skate had a press fit ring welded onto it which seated the cup, the turntable was machined to hold the race and cover the moving parts. Seemed to work ok.
27th Aug 2020, 04:50 PM #3Most Valued Member
- 2,669
I'd be leaning towards tapered rollers too. I wouldn't trust a clutch thrust bearing to support a load.
If you did go down the path of a classic thrust bearing (eg 2 grooved plates and balls between), you'd want to have some provision for taking radial load as the thrust bearings are pure thrust/axial load only.
With the tapered rollers you'd still want to retain the turntables somehow to stop them falling apart when you pick them up - but in use both the axial and radial loads are taken care of by the bearing.
27th Aug 2020, 11:25 PM #4Golden Member
- Apr 2019
- 596
A trailer tapered bearing is designed to take a radial load but I guess it is also designed to handle a side load. Something like an SKF LM67048/10 is rated to 41.5KN static which is over 4 tonnes - should be plenty! It is also cheap as stated
Will give it a go.
Cheers fellas
17th Oct 2020, 10:38 PM #5Golden Member
- Apr 2019
- 596
Finally found time to finish off my machinery skates. Not tested yet but quite happy.
17th Oct 2020, 10:48 PM #6Most Valued Member
Nice work. Where did you score the pallet jack front rollers as the wheels from??
Regards,
18th Oct 2020, 05:43 PM #7Golden Member
- Apr 2019
- 596
The nylon wheels came from Mitaco https://www.mitaco.com.au/products/n...k-front-roller
18th Oct 2020, 07:21 PM #8Most Valued Member
- Mar 2011
- 1,552
I’d be be happy with those too. Well executed.
Where to buy Bearings
By welder in forum METALWORK GENERALReplies: 22Last Post: 5th May 2013, 11:43 AM -
SOLD: 1930's 1940's and 1950's English Mechanic's, Machinery Lloyd and Machinery Magazine
By onetwoone in forum METALWORK - Machinery, Equipment, MARKETReplies: 13Last Post: 21st Jan 2013, 07:16 PM -
Bearings
By Anorak Bob in forum METALWORK GENERALReplies: 10Last Post: 16th Feb 2011, 08:05 AM -
SOLD: 100 skate bearings ABEC 7
By snowyskiesau in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 25th Aug 2010, 10:00 PM -
What Bearings?
By zuffen in forum TRAILERS & OTHER FABRICATED STUFFReplies: 8Last Post: 11th Apr 2010, 09:22 AM
