Results 1 to 2 of 2
Thread: Closed crankcase Hoglet V Twin
13th Aug 2020, 10:09 AM #1New Member
- Mar 2015
- Narre Warren Victoria Australia
- 5
My last project a Closed Crankcase Hoglet. I have used aluminium for the build with steel liners in the cylinders.
Building the crankshaft was the most challenging and getting it to run true, I turned the crankpin down to 5/16 on each end and threaded it and pressed it into the 4''x 1/2 discs using lock nuts to secure it. The main bearings are screwed into the centre of the discs and then I turned them down to 10mmm as a unit .
The main bearings are single row roller bearings. I have used an O ring and a steel piston ring, it compression tests at 160 psi
after the usual first start difficulties I have got it to run reasonably smoothly.
As I am new to this site I hope this post is not inappropriate as this is the work I use my machines for .
I have a Qualos Junior 4 " Lathe and a Hercus 9A Lathe both Dc conversions My Mill is a Chinese bench top machine with all the usual failings
13th Aug 2020, 11:35 AM #2Golden Member
- Dec 2007
- 574
Looks like good work there - well done.
CIGWELD 130 Twin Wire feed
By glivo in forum WELDINGReplies: 60Last Post: 12th Oct 2022, 07:29 PM -
twin tub rotary table
By morrisman in forum METALWORK GENERALReplies: 7Last Post: 21st Jun 2013, 11:51 PM -
Crankcase Clearance
By jack620 in forum METALWORK GENERALReplies: 10Last Post: 4th Apr 2013, 06:22 AM -
Motor twin pulley dimensions ???
By bitza500 in forum THE HERCUS AREAReplies: 2Last Post: 29th Nov 2008, 04:43 PM -
CIG Transmig 130 Twin
By cliff.king in forum WELDINGReplies: 5Last Post: 6th Sep 2008, 05:50 PM
