Results 1 to 6 of 6
Thread: Hercus 9C Pulley Upgrade
8th Aug 2020, 04:00 PM #1Golden Member
- Sep 2009
- 666
Disclaimer; I am not a machinist. I would class myself as a garage hack that likes to do the odd project
I do however love my little Hercus 9C lathe. It was a very cheap grab and after some fettling has served me well for years. It wasn’t really until I tried to turn down some 110mm discs recently though that it really struggled. The major issue was the belt slipping off the flat pulleys.
I didn’t worry about it before now because I quite like the safety of the belts slipping, but I’m now doing more work and it’s becoming a barrier, plus I hope I’m better on the lathe now to not need as much of a safety margin.
I have a great old motor on the lathe on a VFD, so torque is no longer a problem, but putting that power into cuts is.
The solution was a v belt pulley upgrade. It’s not a direct bolt on option but close to it. I had a chat with Mal at Australian Metalworking Hobbyist and was lucky enough to score a recently acquired set of pulleys. For those that have a Hercus and haven’t heard of Mal, acquaint yourselves. He’s a saviour to us Hercus owners.
Step 1 was to bore out the rear pulley. My lathe is an early 1940’s machine with a 7/8” motor pulley shaft. Easy enough to do as I already have a lathe
One that’s done it’s easy to pull the spindle and swap the pulleys.
I don’t have to run the belt as tight as I used to and the motor puts all that power straight in the the spindle. The extra speed also gives me just over 1000 RPM which is great because I’ve now moved over to CCMT inserts and that extra speed will definitely gel better with carbide:
Testing the cutting ability I thought I’d try it on my usual setup, the change gears running on the slowest feed speed. Cuts 25 thousandths with ease and even up to 35 thousandths was cutting but a lot of chatter. So it seemed like 25 was the sweet spot.
Next up I changed the 16 change gear for the 32 to see what effect that would have.... wow! Another level.
Not only did this setup hog material off but the machine was doing it with ease. I was taking 20 thousandths cuts at 800 RPM and the chips were spitting off the insert with a blue hue, incredible. The ones below are from the first set of cuts, but the second setup was flicking off small chips that I couldn’t pull out of the shop vac
Couldn’t be happier, the machine is easily much more capable for a relatively cheap investment!
Next stage will be an electronic lead screw, moving away from change gears as they’re a pain in the bum. Hence why I never change them and leave the lathe setup on the slowest feed.
9th Aug 2020, 08:29 AM #2Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
Far out .pretty neat little set up mate. Ive considered bumping the speed up on my plain bearing hercus c .A fair few times. Not by much just to 900 or 1000. thinking i wouldnt use at flat out very much. I just didnt want to be the guy saying here that ive trashed my spindle and head stock, I really would like a rollor bearing head stock hurcus. ill have to run some tests. to see how far off .025 i can cut with the factory set up.
Any qay i am sure Mal wouldnt steer you wrong. so looks like a preety good upgrade.
9th Aug 2020, 09:00 AM #3Golden Member
- Sep 2009
- 666
Top speed is around 900 RPM I think on the C according to Mal, but I tend to max on the second last pulley which is just shy of 900 RPM. I’m like you, don’t feel that comfy going flat out on the highest pulley.
According to Mal the C has a higher material removal capability because of the lack of torque being used for crossfeed etc. I can certainly say my C has a lot of material removal power now, which will make a huge difference to turning times.
Would be interested to compare material removal vs the flat belts. Let me know how you go and I can compare from my end too. The material I was playing with yesterday was pretty tough, non descript steel.
9th Aug 2020, 10:51 AM #4Most Valued Member
- Oct 2010
- 1,910
UMM i had a feeling that the c modal was ment to be 700 plus rpm top speed. That's just a hasey guess.
random mystery steel hay. i now it well.
9th Aug 2020, 11:00 AM #5Golden Member
- Sep 2009
- 666
Reading a home shop machinest thread looks like you might be right, but plenty of people running plain bearing southbends at 800-900 rpm for years with minimal impact. I’m not sure I’d run mine much above 850 RPM as even then is humming along pretty fast.
I’d likely keep the pulley with the best torque (second down) and run the motor a little faster to keep the torque.
I noticed that on the carbide run the chip load got better the smaller the diameter got (at about 600 RPM), so I suspect 850 is probably the max with the 32T running the feed.
That’s the annoying thing about change gears, you can’t easily try different feeds. Hence the reason I’m going electronic leadscrew at some point. Also means I can get rid of the eBay RPM gauge.
For those that haven’t seen it, this is what I’ll be buying in to. Looks like an amazing bit of kit:
https://youtu.be/10Ketpqq-eM
2nd Jan 2023, 10:30 AM #6Senior Member
- Aug 2021
- 46
- 116
Interesting thread and hope its no problem to bring back a thread from 2020.
Really lovely looking lathe and nicely set up there neevo.
Happy New Year,
Steve.
Hercus Mill Upgrade
By hpa1 in forum THE HERCUS AREAReplies: 4Last Post: 6th May 2020, 10:08 PM -
Hercus 260 CTM upgrade
By boilermaker8 in forum THE HERCUS AREAReplies: 2Last Post: 17th Nov 2011, 05:46 PM -
Hercus upgrade
By .RC. in forum METALWORK GENERALReplies: 13Last Post: 16th Oct 2010, 11:37 AM -
early hercus pulley covers
By allterrain50 in forum THE HERCUS AREAReplies: 2Last Post: 9th Jul 2009, 11:01 PM -
Hercus V pulley and B/g set ebay
By malb in forum THE HERCUS AREAReplies: 3Last Post: 6th Oct 2008, 01:37 PM
