Results 1 to 3 of 3
Thread: Table Saw Fence Fine Adjust
22nd Jul 2020, 06:41 PM #1Most Valued Member
My table saw had a rudimentary fine adjustment system for the fence. Just an M8x1.25 bolt running in a very sloppy threaded hole in the aluminium fence.
It had a huge amount of backlash and 1.25mm is a stupid pitch for a vernier. I had a 9x1mm tap and die so I made a new bolt out of a piece of 19mm Stressproof. The nut is PB1 bronze. I single pointed the thread to close to tolerance then ran the die over it. The result is a very snug fit with negligible backlash (for a woodworking tool anyway). My dividing plate doesn't have any multiples of ten, so I printed off a template and rigged up a Heath Robinson pointer.
The fence is now much better than it was and I have a 0.1mm 'vernier' on my table saw fence. Should have done it 25 years ago.Chris
23rd Jul 2020, 09:41 PM #2Most Valued Member
- Healesville
- 2,129
G/day Chris, it's crazy that the manufacturer didn't put a 1mm thread there to start with, nice job m8.
Did you get that Stressproof steel locally?
23rd Jul 2020, 10:19 PM #3Most Valued Member
Thanks John.
My model diesel engine plans called for Stressproof for the crankshaft. I contacted Niagara Lasalle about an Australian importer. There wasn’t one, so they sent me 6 x 6” lengths from the US free of charge.Chris
TIG was working fine. Now this...
By kenbartos in forum WELDINGReplies: 7Last Post: 1st Apr 2020, 06:34 PM -
How to adjust burn back on Unimig Razor weld Smart Set 205
By PennyN in forum WELDINGReplies: 20Last Post: 10th Feb 2019, 08:44 PM -
How do you adjust a tailstock?
By Vernonv in forum METALWORK GENERALReplies: 8Last Post: 13th Sep 2014, 11:32 AM -
Attaching long miter fence to Robland X31 sliding table.
By Timless Timber in forum METALWORK GENERALReplies: 0Last Post: 10th Sep 2013, 02:47 AM -
How to adjust gibs
By 19brendan81 in forum METALWORK GENERALReplies: 2Last Post: 25th Nov 2009, 10:29 AM
