Results 106 to 107 of 107
Thread: Power tool and cutter grinder
9th Feb 2021, 11:05 PM #106Most Valued Member
- 2,671
Thanks Shed.
You’re reading it correctly.
TBH I struggled a bit with with the setup, and was definitely grinding away from the cutting edge rather than into it.
A lot of that was my tooth rest arrangement being less than ideal, and I think the 10mm cutter is really too small for indexing that way.
I spent a bit of time last night making a new sleeve with a better fit in the workhead, and a larger retaining collar with indexing slots like BC showed earlier.
I just need to cut the slots now to finish it.
Should make the indexing easier and will allow me to use the other side of the wheel so I’ll be grinding into the edge.
14th Feb 2021, 09:15 PM #107Most Valued Member
- 2,671
Finished off the indexing collar, then found I didn’t have enough clearance to get the index finger set up. Made up a rough holder so I could mount it higher - the same index finger I used previously slides up inside the bore.
Was going to have a crack at this roughing endmill I buggered last year as it’s a decent size to learn on and I can’t make it any worse that it is now - but after cutting the end off with the angle grinder I realized that it’s obviously not going to fit in the ER20 holder
So had another play with drill faceting.
Angles aren’t right but I was happy with how the indexing worked and the finish.
A gear cutter grinding jig for tool and cutter grinder.
By steamloco1954 in forum METALWORK GENERALReplies: 1Last Post: 30th Mar 2020, 07:30 PM -
Hercus tool and cutter grinder & cylindrical grinder.
By stix012 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 23rd Aug 2018, 05:31 PM -
Another Tool And Cutter Grinder
By Anorak Bob in forum METALWORK GENERALReplies: 26Last Post: 13th Nov 2013, 12:15 PM -
Tool and Cutter grinder
By 4-6-4 in forum METALWORK GENERALReplies: 2Last Post: 12th Oct 2011, 11:40 PM
