Page 2 of 8 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 107
  1. #16
    Feb 2009
    jilliby nsw
    111
    This is my T & C grinder
    Some of the attachments I made for the workhead
    IMG_0493.jpgEr 32 collect holder
    IMG_0492.jpgTool post for doing lathe tools. Also a 3 jar chuck attachment
  2. #17
    6,444
    Hi Ian,
    Now how did you fasten it up there
  3. #18
    Feb 2009
    jilliby nsw
    111
    Haha, yes upside down pics. For some strange reason when I added the images from the photo library the algorithm chose to place 2 of them upside down and despite numerous attempts at adding pics to the post there was no way the computer was going to cooperate! Anyhow I reckon that an upside down pics is better than no pic
  4. #19
    6,444
    Hi Ian,
    Quote Originally Posted by hpa1 View Post
    The secret is to edit the picture and re-save it ! Just re-saving doesn't remove the "EXIF" data embedded in the picture. Its the EXIF data that tells the computer which way up it should be plus a lot of other data you might not want to share.
    I usually just crop the outside edges off and save. If needed it also allows me to resize a picture.
    HTH.
  5. #20
    Nov 2017
    Geelong, Australia
    57
    2,651
    Thanks, and upside down is definitely better than no photo. Forced me to copy them to my PC so I could have a decent look anyway
    This Power grinder has a 900mm square base.
    Yours looks to be a bit smaller than that but always hard to tell from photos (learned that lesson when I bought a horizontal bandsaw a couple of years ago that I thought was only a pallet wide from the photos. Turned out to be sitting on a DOUBLE width pallet and was 1.4T )
    Those attachments look great. Nice job!
    I spent an hour last night just faffing with it, spraying the surface rusted areas with acetone/ATF mix and and starting to clean them up.
    Only obvious damage so far is some damaged handwheel handles, and one of the handwheels has taken a whack at some point and cracked a chunk out next to the handle spindle.
    Haven't worked out yet what the deal is with lubrication of the ways. I can see inside the base there is a copper tube that looks to be running from the front to rear of the saddle ways, but as yet haven't found any obvious points to actually put oil in.
    The spindle and column have grease nipples.
  6. #21
    Nov 2019
    Brisbane
    69
    452
    Default T & C pulley
    Quote Originally Posted by Toggy View Post
    On the 2nd pic of the cincy with the drive pulley. Appears to be the flat belt drive pulley for the internal grinding spindle.
    What are the width and diameter dimensions please as I have to make one.
    Ken
    Hello Ken.
    I have just measured the pulley at 5" diameter and 1" wide. The coning is about 5 thou. My model has a split casting to hold the spindle cartridge and 2 jacking bolts to open it up. Looks like they wanted to make it easy to change the belt.
    BC
  7. #22
    Jul 2008
    near Warragul, Victoria
    3,718
    Default No2
    I've got a Cinci No2 without any accessories . It's a ex Tafe or Tech school machine by the look of it , been painted with horrible blue and yellow enamel . Am thinking of passing it onto somebody with more expertise than I have
  8. #23
    Nov 2017
    Geelong, Australia
    57
    2,651
    That would count me out then
    I’m a complete newbie brewing lots of dumb questions while i bring this one back to life....
    I wouldn’t think you’d have too much issue moving it on if you decide to.
  9. #24
    Jun 2004
    Kyabram. Vic
    632
    Thanks BC. That gives me a walkup start for making a replacement drive pulley. Then to make a mount for the internal grinding spindle cartridge.
    Tomorrow I will measure mine up and get back with the measurements. I haven't removed my bellows yet as their damage is just below the top clamping flat. The Elliott has a motorised head with a high speed output (belt driven step up) and a straight low speed drive.
    Ken
  10. #25
    Nov 2017
    Geelong, Australia
    57
    2,651
    Default Power tool and cutter grinder
    Found the grease nipples for the saddle lubrication.
    Still no sign of any way of lubing the table ball ways, but I've just checked in the Cinci #2 manual and it says:
    " The table rides on precision ball bearings. These and the ways should be cleaned and dried periodically, but should never be oiled or greased as oily lubricants eventually pick up grinding grit.
    After cleaning, dust the balls lightly with colloidal graphite "
    Is that the same graphite powder you use to lubricate door locks?
  11. #26
    Feb 2009
    jilliby nsw
    111
    Steve the machine may look complicated and scary but its not. Basically its a mounted bench grinder and a workhead which give you the ability to move the tool your sharpening in any of X,Y&Z axis as well as rotary motion. So to use the machine work out what you want to sharpen and then work out what standard machine accessories you can use for the job and what you need to beg, borrow or make to complete the task.
    For example for me to sharpen the end of an endmill, I needed something to hold the tool, so I made the ER32 collet adaptor to fit onto my workhead so I had 2 planes of movement to get the angles needed. the 3rd plane of movement is provided by the grinding head settings. The workhead spindle can be indexed by degrees or direct indexed to cater for the number of facets that need to be sharpened ie. 2, 3. 4, etc. Once you can get your head around the sharpening process (tool angles & setup) the rest will fall into place. There are a number of T&C sharpening books around that will tell you the recommended sharpening angles needs for a variety of tooling. There are also a variety of attachments commercially made to hold tooling such as drill sharpening jigs etc.Hope this hasn't confused you too much it is a little difficult to cover "how to" thoughts and processes into a few lines of print
  12. #27
    Nov 2017
    Geelong, Australia
    57
    2,651
    Thanks hpa1.
    I've grabbed all the online T&C books I could find over the last few months. I think I've now got a basic idea of what needs to be done, but I'm sure the devil is in the detail. I'm sure the devil is in the detail though, and only experience will help with that.
    Fortunately I've gotten quite good at making blunt/damaged cutters, and have been building up a stockpile to practice on
    Apart from cleaning it up and actually getting it running, I'm going to need some form of indexing as the current workhead doesn't seem to have any. Its basically just a rotating morse taper socket with a clamping screw to lock it (unless there's something I've missed).
  13. #28
    6,444
    Hi Steve, Guys,
    Usually there is some kind of a finger that runs in the flutes of a cutter to provide the indexing.
  14. #29
    Nov 2019
    Brisbane
    69
    452
    Default T & C indexing
    Thanks hpa1.
    Back again. In a previous post I showed some of my indexers. I have simple and adjustable factory units and home built as well. If you can't find them in a search of my posts message me and I'll repost. A spin indexer can be used and is good at gashing the cutter end.
    regards
    BC
  15. #30
    Jun 2004
    Kyabram. Vic
    632
    Steve,
    I took some measurements today. The Elliott column is 630mm diameter which my calculations give me 190mm or in its imperial measurements 7+7/8 inches. Appears about correct from eyeballing a vernier.
    It has 275mm elevation (10+7/8" --11" when of the lift screw.
    The rubber bellows are 1.19mm or 0.0430"
    The top of the bellows clamp to a vertical surface via a jubilee style clamp. The bottom clamps to the horizontal surface of the base via two screwed down steel clamps.
    As an aside the head is stamped 220 380 440 3ph 50G. I am guessing the 50G denote 50 hertz. I have not opened up the motorised head to check the electrics but will have to do so soon due to dry bearings which I assume will be some type of preloaded bearings. Even though I power it via the rotary phase converter the 220 suggests a VFD could be used.
    I have hijacked your thread a bit but the info may be of use to somebody looking for information.
    Ken
  1. A gear cutter grinding jig for tool and cutter grinder.
    By steamloco1954 in forum METALWORK GENERAL
    Last Post: 30th Mar 2020, 07:30 PM
  2. Hercus tool and cutter grinder & cylindrical grinder.
    By stix012 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 23rd Aug 2018, 05:31 PM
  3. Another Tool And Cutter Grinder
    Last Post: 13th Nov 2013, 12:15 PM
  4. Tool and Cutter grinder
    By 4-6-4 in forum METALWORK GENERAL
    Last Post: 12th Oct 2011, 11:40 PM
