Results 16 to 17 of 17
Thread: First furnace build
31st Oct 2020, 01:28 PM #16Most Valued Member
- 2,651
Got the main body refractory done this morning. Took a solid couple of hours.
Mixing method
if my last post wasn’t clear
1st Nov 2020, 05:11 PM #17Most Valued Member
- 2,651
First furnace build
Pulled out the inner former and found that the burner and preheat tubes had moved slightly allowing refractory to enter from the inner end. About 50mm thick in the case of the burner tube
Spent a bit of time drilling and fettling with a masonry bit while it’s still somewhat green and not super hard.
In hindsight I should have cut the domed top off the lid to reduce the volume of refractory. It’s about 150mm deep in the middle.
Might need a bigger lever on the foot pedal to lift it!!
Will leave both lid and body covered in plastic for now for a month or so, so it doesn’t dry out too fast.
Furnace kit
By AndrewOC in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 28th Apr 2015, 12:29 PM -
Furnace build
By Ueee in forum THE FOUNDRYReplies: 28Last Post: 9th Apr 2015, 12:20 PM -
Furnace Build(likely to be very slow)
By Stustoys in forum THE FOUNDRYReplies: 43Last Post: 15th Jul 2013, 04:18 PM -
Diesel Powered FURNACE build
By SawDustSniffer in forum THE FOUNDRYReplies: 28Last Post: 24th Oct 2012, 02:36 PM -
help me build a basic flat build bed trailer for my kayaks
By gros21 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 7Last Post: 13th Oct 2011, 08:47 AM
