Results 1 to 7 of 7
Thread: Kafer indicator
    Apr 2012
    Healesville
    2,129
    Default Kafer indicator
    I received this indicator from UK ebay the other day, it was advertised as "in excellent condition"..........
    It was stuck good and proper, a clean with acetone and bit by bit it came good.
    The next problem arose when I broke the placka thingo, I thought it was just being stubborn and the circlip wouldn't let it go
    The placka bit is held on by 3 spring clips under the inner face and there was no way I could get that needle off and I didn't want to damage those bits as well.
    Oh well....I am more into function than form so I thought I would work around it, it ended up being 1mm bigger in diameter.
    This is what I did and it works like a beauty
    Feb 2014
    Werribee, Melbourne
    178
    Nice work!
    6,480
    Hi John,
    It looks beautiful ! A unique gauge I must say.
    May 2020
    Wisconsin, US
    40
    13
    Excellent Lathe work! Is that one of those mini lathe machines? How does the blade hold up when you use it on metals like so?
    Apr 2012
    Healesville
    2,129
    Hi TIG, the material is phospher bronze and it is pretty easy to machine. The chuck is a 80mm mini ĺathe
    chuck mounted on a backing plate with an arbour and this mounted in a 300mm 4 jaw chuck.
    The lathe is much the same as this https://www.machineryhouse.com.au/l600d
    The lathe and tooling thought that they were cutting air on that job.
    May 2020
    Wisconsin, US
    40
    13
    Thanks for clarifying
    Phospher bronze.. I guess you learn something new everyday! I knew of bronze but not of that specific alloy. I bet that the lathe cut through it like through butter
    How do you find having a lathe in the garage? Is it a useful tool to buy?
    Apr 2012
    Healesville
    2,129
    Quote Originally Posted by TIG_Is_My_Jam View Post
    I think that is the best place for it, much more peaceful there than in the house..
    For me (and many in this forum) yes..... but the sad truth is that most ppl these days can't even use a screwdriver so only
    you could answer that question for yourself.
  1. Indicator holder.
    By BaronJ in forum METALWORK GENERAL
    Last Post: 13th Feb 2016, 08:06 AM
  2. Indicator Sag.
    Last Post: 30th Sep 2015, 10:21 PM
  3. Indicator Point !
    Last Post: 17th Dec 2014, 07:14 AM
  4. dial indicator
    By fittermachinist in forum METALWORK GENERAL
    Last Post: 12th Aug 2012, 12:20 AM
  5. Not a DRO - An indicator instead.
    Last Post: 16th Nov 2011, 10:07 PM
