Results 16 to 24 of 24
Thread: Rotary table grinder
19th Jun 2020, 06:36 PM #16Most Valued Member
- Healesville
- 2,129
moved the grinding head
A little progress here, I put a scissor jack between the 2 machines and got a more control on the grinding.
I found that it is impossible to grind on a sunny day, overcast with drizzle is the best as the distance between the 2 machines
stays pretty constant.
I have finished the roughing down and repositioned the grinding spindle and motor, so far I have only ground one side edge,
now waiting on some nice overcast drizzley weather to finish grinding.
I thought this would be a good candidate for Turcite B, it should arrive August or Sept.
19th Jun 2020, 06:55 PM #17Most Valued Member
- Healesville
- 2,129
Grinding shaft
The shaft is a bit worse for wear, also had holes drilled in the wheel flange thread, I reckon at some stage it might have been running backwards and undoing the nut so some nit wit drilled it and put a pin through to stop it undoing.
The bearings on this ran on grease and were pretty much not sealed in any way so I have modified it a bit and are fitting seals so that it will run in oil.
When I get the tool and cutter grinder parts off the mill then the shaft will get a keyway.
19th Jun 2020, 07:02 PM #18Most Valued Member
- Healesville
- 2,129
pity the shaft didn't fit
The old shaft was thinned down for most of it's length, reason for that is that the hole in the casting is offset to the shaft and not straight, basically it had a long high spot that interfered with the new shaft. I didn't want to reduce the shaft dia so i got in there with a boring bar made out of a toyota dyna axle.
I did a short clip of the set up https://www.youtube.com/watch?v=Db8Z_aaKUd4
20th Jun 2020, 07:21 AM #19
Hi Shed,
You have been doing some really nice machining work What make is your mill?
Mark.
20th Jun 2020, 12:20 PM #20Most Valued Member
- Jul 2016
- 35
- 1,522
A set up just isn't right unless there is a big G clamp somewhere.
20th Jun 2020, 07:34 PM #21Most Valued Member
- Healesville
- 2,129
Thanks Turbs, it is an Anayak, here is a thread I did on some repairs to it https://metalworkforums.com/f303/t20...ghlight=anayak
20th Jun 2020, 11:20 PM #22
AH!!! yes i remember and she heavy duty nice The table feed gearbox on your mill is similar to my rambaudi mill table feed gearbox.
21st Jun 2020, 04:30 PM #23Most Valued Member
- Healesville
- 2,129
21st Jun 2020, 04:49 PM #24
Rotary Table
By Picko in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 6Last Post: 6th Aug 2020, 08:33 AM -
Rotary Table ID
By bollie7 in forum METALWORK GENERALReplies: 1Last Post: 15th Jan 2019, 11:07 PM -
WTB Rotary table
By KBs PensNmore in forum WANTED TO BUYReplies: 0Last Post: 17th Nov 2018, 11:57 PM -
Rotary table ID?
By bollie7 in forum METALWORK GENERALReplies: 12Last Post: 2nd Nov 2017, 08:37 PM -
Rotary Table
By graemet in forum METALWORK GENERALReplies: 26Last Post: 8th Oct 2008, 09:34 AM
