Results 1 to 3 of 3
Thread: New Lathe Table
    Nov 2017
    Australia
    35
    Default New Lathe Table
    G’day everyone I’ve recently started making a new lathe table as the old one was flimsy and not very solid. It had actually sunk on top. I’m just wondering how thick I should make the top I’m thinking around 8mm but I probably only really need sheet metal.
    Just wondering if anyone has any experience in what would be good or what might be better in the design?
    May 2011
    Murray Bridge S Aust.
    5,959
    As long as you're able to bolt the lathe to the frame, sheet metal will be fine, I suggest 1.5 mm and putting a back on it also, as it'll stop a lot of the swarf from falling down the back between the wall and lathe.
    Not knowing how you're off for storage, I'd put a couple of drawers either under the bench or down one/both sides, to store the at hand tools, chuck key/s, drill chucks, measuring tools etc. You don't want to be walking around looking for the tools.
    Nov 2017
    Australia
    35
    Yeh it will bolt to the frame. Back is a good idea I do tend to make a mess. I do have plenty of storage but drawers are a great idea I love storage
  1. Cleaning Cast iron surfaces : Mill Table & Lathe Ways
    Last Post: 4th Dec 2019, 07:16 PM
  2. New front mounted 4 jaw chuck for rotary table and lathe
    By j3dprints in forum METALWORK GENERAL
    Last Post: 9th Jul 2017, 02:17 AM
  3. Box tubing clamp for holding table leg to table frame
    Last Post: 11th Jan 2017, 12:05 PM
  4. Mounting and centering lathe chuck on rotary table
    Last Post: 19th Mar 2014, 09:00 PM
  5. Table saw for metal lathe
    Last Post: 18th Feb 2014, 05:42 PM
