Results 1 to 12 of 12
2nd Apr 2020, 02:16 PM #1Golden Member
- Apr 2018
- Drouin Vic
- 635
Line boring, and a PTO for the lathe.
I posted a question about line-boring setups a few months ago, seeking inspiration for how I was going to go about boring the frame for my tractor front-end-loader. I put a few ideas from other people together, plus a little of my own brainstorming, and got the job done. This might be of use to others attacking this procedure in the future.
I made a shaft with a splined end to replicate the PTO output on a tractor.
The shaft was held in the lathe chuck, with the splined end protruding out of the back end of the spindle bore, with a simple tapered collar keeping the back end concentric.
I made up a socket to slide over the end of a length of 25mm shaft; the socket is keyed to the shaft and splined on the other end, same PTO splines as the lathe output shaft.
These two splined shafts enable the 25mm boring shaft to be driven from the rear of the lathe via a telescopic PTO drive shaft from a tractor implement, in this case my slasher. For those unfamiliar, a tractor PTO shaft is like an automotive prop shaft, with a uni joint at each end and a sliding section between. The sliding section enables the shaft to extend / retract to accommodate the feed of the boring operation.
I used a steel-topped welding bench to set up the boring job, the business end of the loader frame was plonked up on the steel bench and tacked in place with scrap metal legs. I used flange-mount self-aligning bearings to carry the boring shaft, everything welded to the steel bench to provide a stable setup with the correct relationship between the boring shaft and the work, aligned behind the lathe so that drive and feed could be taken from the lathe.
The next bit was the fun part- taking feed from the lathe as well as rotational drive.
The boring shaft is free to slide through the four flange-mount bearings that keep it aligned in the bore. A fifth bearing- this time in a pillow-block housing- was fixed to the shaft with grub screws to keep it in place longitudinally. this was attached to a jury-rigged arrangement that connects back to the lathe toolpost, so that feed can be applied to the boring shaft from the lathe.
boring shaft feed setup.jpgline boring shaft and feed setup.jpgline boring feed toolpost.jpg
The boring was done with a HSS cutter mounted in a cross-hole hole in the boring shaft, using vernier calipers to extend the cutter the required amount between passes.
The setup worked a treat, although I had to add some bracing to the frame of my welding bench to make it rigid enough for the purpose. Had to add some extra bracing to the boring shaft carrier bearings and loader arm ends as well before it was all rigid enough to cope with the interrupted cut I was getting until the bores neared alignment.
Facing the ends of the bores was problematic. The 'proper' line-boring units have a facing gadget that feeds the tool across the face but I had to find another way. I started by using the surface grinder to make a tool with a long, straight cutting edge to sweep the face.
and promptly snapped it off in the first cut.
The second attempt went better, essentially a shorter version of the same tool, starting with a smaller diameter sweep and extending it out in around .150" increments, blending the surface of each subsequent pass. The outer part of the barrels has been hardened by the process of welding them in place, the HSS cutter would not cut beyond a certain point so they will need to be ground off but there is enough surface with a face square to each bore.
2nd Apr 2020, 07:00 PM #2Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
Impressive Frankenstein-ing of a line borer!
For the facing, a die grinder clamped to the shaft?
3rd Apr 2020, 08:47 AM #3Golden Member
- Apr 2018
- Drouin Vic
- 635
3rd Apr 2020, 01:56 PM #4Member
- Sep 2010
- Port Sorell, Tasmania
- 74
That's an impressive example of improvisation Pete
5th Apr 2020, 12:02 PM #5
Thinking out of the box
Good one mate,
7th Apr 2020, 06:03 PM #6Golden Member
- Apr 2018
- Drouin Vic
- 635
I made a puller to insert the bushes into the bores that were line-bored above. The bushes were made with an interference fit of .0025" so it was always going to be a challenge to get them into the bores. The puller consists of a 12" length of unknownium bar with a 1" 20tpi UNEF thread, and a nut made from an offcut of 4140 with a full 2" of thread. Both threads cut with single-point HSS tooling in the lathe. Milled two flats on the nut to get a big shifter on and drilled a 5/8 hole through the end of the threaded rod to put a bar through.
The bushes have been in the freezer for several days while I got things organised, then the barrel started out nice and warm from grinding the outer part of the faces back. I introduced the cold bush to the warm bore and started turning the puller. Got to the point where I could not turn it any more, obviously by this time both parts are at the same temperature a the bush is only half-way in.
The thing would still move if I could turn the screw, but it had got so difficult to turn that it was defeating me. I had expected my threads to strip before it got to this stage. I was brainstorming ways of applying more torque to the screw than I was able to apply by hand with the bar I had. Came up with the ridiculous idea of attaching something to the wheel of the tractor to apply the rotation required- I considered using the PTO but that turns too fast and I also didn't want to risk damaging the internals. Considering that the tractor in Low 1st goes slower than walking pace and the wheels are about 5' diameter, i guess the axle turns pretty slow. Why not give it a shot.
I cobbled together an adaptor to attach to the wheel, with a sliding offcut of triangular PTO shaft welded in the centre and slotted at the outer end to drive the screw.
Lined the tractor up alongside the business end of the loader frame and jacked up the rear end of the tractor, then slid the outer of the shaft over the screw.
Both rear wheels off the floor and diff lock engaged to get the slowest possible drive.
I was expecting the threads to strip straight away, but they held. The bush came in ever-so-slowly. The cast-iron gear I was using as a spacer (first thing I picked up with the right size bore) shattered at one stage and I thought the threads had let go after all. I replaced the gear with something else that came to hand with the right size hole and continued. Things shuddered and complained a lot as it got close, then pretty much stopped with the bush about .020" short of home. I think I'll call it good. I used reverse gear to back the puller off but all that achieved was busting the end of the drive shaft. Will need some modification before attacking the rest of the bushes but i'll consider the concept proven.
Your Message
[COLOR=#3E3E3E]Title:
[COLOR=#000000][FONT=Arial][TABLE="class: cke_editor, width: 1309"]
[TR]
[TD="class: cke_top"] FontSizeLast edited by Pete O; 7th Apr 2020 at 07:16 PM. Reason: re=load pictures
7th Apr 2020, 06:20 PM #7Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
No pics showing.
"Invalid Attachment specified. If you followed a valid link, please notify the administrator"
JohnQ
7th Apr 2020, 07:09 PM #8Golden Member
- Apr 2018
- Drouin Vic
- 635
7th Apr 2020, 07:17 PM #9Golden Member
- Apr 2018
- Drouin Vic
- 635
Re-loaded the pics, someone please let me know if they are showing now.
7th Apr 2020, 10:15 PM #10Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
Yes, I can see 7 photos Pete. Good job by the way.
10th Apr 2020, 09:36 AM #11Senior Member
- Nov 2011
- 123
All good tks
11th Apr 2020, 06:12 PM #12
Hi Pete,
I wonder if some oil would have helped ! Though now its cooled off heating the outer whilst applying pressure to the bush would see it home.
Either way nice improvisation.Best Regards:
Line boring job to do...looking for inspiration.
By Pete O in forum METALWORK GENERALReplies: 12Last Post: 25th Nov 2019, 09:19 AM -
Line boring dingo loader arms
By .RC. in forum METALWORK GENERALReplies: 35Last Post: 16th Nov 2015, 07:48 AM -
Line boring on the mill
By Ueee in forum METALWORK GENERALReplies: 30Last Post: 5th Jan 2014, 09:02 AM -
Put My First Line Boring Job on Youtube
By beefy in forum METALWORK GENERALReplies: 9Last Post: 24th Jun 2013, 11:26 PM -
Large engine metal spraying and line boring
By new_guy90 in forum METALWORK GENERALReplies: 0Last Post: 27th Feb 2012, 10:00 PM
