Results 1 to 3 of 3
Thread: Ratchet Cog's
    Jun 2007
    Ipswich QLD
    68
    1,997
    Default Ratchet Cog's
    Got asked by Sue's friend to replace 2 poorly made ratchet cogs off a table loom these had been made from old chopping board material one had lost 3 teeth.
    Got some 6061 bar stock
    Drew up new cogs with 18 teeth machine blanks to size. Each cog had a slight .5mm rise to keep the cog away from the frame of the loom so it will not ware or rub against.
    Made an arbour to mount the 2 cogs on simultaneously cutting each in opposite directions when mounted, the flat faces together. Using 60^ cutter at depth of 3mm x 10mm into the quadrant to form the ratchet.
    Not bad for my first milling job, just need to double check everything in future is tight before & during.
    20200204_122747[1].jpg20200204_163124.jpg20200212_105431.jpg20200213_101331.jpg20200214_120003.jpg
    May 2011
    Murray Bridge S Aust.
    5,959
    Great work Ray. Only problem is that the part is so strong, what will she break next.
    Jun 2007
    Ipswich QLD
    68
    1,997
    Kryn she had not used it at all it was a recent acquisition and being an 8 shaft well worth the trouble to have a new one made. Besides the lady looks after me with sales to the spinners group and sometimes brings or send cakes home with Sue This job was $$ tho no cakes.
  1. Ratchet and Pawl source
    By SurfinNev in forum METALWORK GENERAL
    Last Post: 10th Dec 2019, 08:33 PM
  2. Douglas shaper ratchet
    By Ueee in forum METALWORK GENERAL
    Last Post: 19th Sep 2013, 12:23 PM
  3. Shaper table feed ratchet
    Last Post: 7th Jun 2012, 02:27 AM
  4. VICTORIA Powerbuilt Sockets, Ratchet, Breaker bar, 3/4"
    By TermiMonster in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 6th May 2012, 09:14 PM
