Results 1 to 5 of 5
    Oct 2006
    Newcastle
    124
    Default Couple of Press improvement on a damp day
    Bit damp on the east coast so a good time to head to the shed and make a few improvements to the new press.
    Castor wheels to help move it around my ever decreasing work space,
    Nylon sleeve on jack handle for a better fit,
    an alloy knob for jack release to hopefully improve control.
    and an extension for the "ram"
    I'm also wanting to make a hand wheel for raising nd lowering of the Jack thread, but that will hve to wait till I source a suitable piece of steel the right size.
    Hafco AL320G Lathe
    Toolex RF31 Mill/Drill
    Saber Bandsaw
    Oct 2006
    Newcastle
    124
    putting the new press to good use, removing dents from my "dirt" wheelset. its not perfect but I'm happy enough with the result for a first attempt.
    Hafco AL320G Lathe
    Saber Bandsaw
    Aug 2011
    Perth, Western Australia
    67
    362
    Some good mods on the press there Oldhack.
    Check the rims fine cracking. Some ali rims will bend once and not crack but when bent back small cracks can develop.
    Tony
    Oct 2006
    Newcastle
    124
    Quote Originally Posted by bts View Post
    Tony
    I had thought about apply a small amount of heat, but was concerned about making the alloy brittle .
    Hafco AL320G Lathe
    Saber Bandsaw
    Oct 2010
    melbourne, laverton
    1,910
    hi you can anneal aluminium, Im not sure if its suitable for this job. just use the soot from acetalean only to the metal then heat till the soot disappears
    aaron
  1. Restoration Projects - Tough Drill Press - Dawn Drill Press - Record Pipe Vice
    By bwal74 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 10th Feb 2019, 03:11 PM
  2. Replies: 4
    Last Post: 1st Jul 2013, 09:12 PM
  3. Damp welding rods.
    By Rowley in forum WELDING
    Last Post: 7th Mar 2012, 11:15 PM
  4. A couple more 9As...
    By festy_ in forum THE HERCUS AREA
    Last Post: 1st Jan 2011, 05:22 PM
  5. Couple Q's
    By Unit_01 in forum METALWORK GENERAL
    Last Post: 4th Apr 2007, 09:41 AM
