Results 1 to 15 of 19
Thread: Drill grinding on a budget
25th Jan 2020, 01:21 PM #1Senior Member
- Nov 2019
- Brisbane
- 69
- 452
SAM_0585.jpgSAM_0584.jpgHello from the old goat.
Many years ago after suffering a few cheap plastic attachments I bought this. My drills improved in accuracy and flat bottom or zero angle drills became my norm.
A good project for the wet day.
BC
25th Jan 2020, 02:23 PM #2Member: Blue and white apron brigade
- 7,182
It would really help declutter the forums and save the mods work if posts on the same topic especially by the same member were posted into the same thread. Even better would be to search for a preexisting thread on the same topic and post into that.
25th Jan 2020, 05:22 PM #3
Great idea Bob,
Drill sharpening is an oft visited topic.
If there are not too many who oppose the idea, I am quite willing to start a thread myself and move any "strays" into that thread when and where they come up.
Same for other general "how to" type topics as they come up.
There ya go boys, what do you say to that one ?
26th Jan 2020, 11:58 AM #4Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Drill grinding
Hello Grahame.
Yes drill grinding is a topic often commented on. Tool and cutter grinding is a general topic not well understood. Also good information is scattered and hard to find. Then it must be verified. I am currently trying to locate a copy of a book, The Art of Tool and Cutter grinding by J.P Narang. No luck so far but I have seen it described as one of the best on the subject.
Any chance of a sub forum for all tool grinding and toolroom work? This makes it fairly broad in scope but still specific. There is a Facebook group for tool and cutter grinders. It seems to be for the CNC guys and other enquiries don't rate an answer. So much can be done in the small shop with a good 6" bench grinder. Harrold Hall's book is a good start.
What do you think.
BC
27th Jan 2020, 09:41 AM #5Golden Member
- Mar 2009
- 54
- 825
Problem with this is that the search function only links to the first page/post of a thread containing the search term, not the actual post containg it. This means you need to trawl through dozens if not hundreds of posts, often irrelevant to the topic at hand, in order to find the gems of info you're looking for, if they even exist.
Individual threads mean you can assess the validity of the information, idea or suggestion by reading, at worst, the first few posts of the thread which is where the search engine sends you. Some of the threads on here go north of fifty pages and spend more time off topic than on. These threads, which can contain small amounts of fantastic and useable information are now pretty much worthless because it is too difficult to find.
Greg.
27th Jan 2020, 10:41 AM #6Most Valued Member
- 2,651
FWIW I always use Google for searches, and never use the forum search. To restrict the results to just this forum use "site:metalworkforums.com" in your search.
The Google result typically takes you to the actual post containing the search phase.
27th Jan 2020, 11:19 AM #7Most Valued Member
- 2,651
27th Jan 2020, 10:23 PM #8Senior Member
- Feb 2009
- jilliby nsw
- 111
Hello Grahame, having just aquired a fairly complete T &C Grinder I for one would benefit from a T&C forum. which would hopefully cover sharpening techniques for a range of metalworking cutters and hopefully the jigs, commercial and DIY used to accomplish the tasks. Been nearly 50 years since I did the trade and my memory needs a refresher / reboot with this machine. Thanks
28th Jan 2020, 12:27 AM #9Golden Member
- Sep 2009
- 666
I’m working up some plans based on this video:
https://youtu.be/9wxnwwOzTh0
The plan is to build the jig against my bench grinder with a diamond wheel as the grinding medium.
Some parts are really cheap to buy ready made. For example I can buy an ER16 collet chuck (with straight shank) for $15, I can’t even buy a 22x1.5mm die for less than that.
Not sure it will work but I’m pretty confident I have it all planned out. I reckon around $80-$100 less the collets and grinder.
I’ve usually ground drills by hand but never really mastered the art and I cannot hand grind them for small ones. The hope is that this offers the precision required to properly grind 2-4 facet drills but to also do it with accuracy for 2mm drills too.
28th Jan 2020, 01:05 AM #10Member: Blue and white apron brigade
- 7,182
That's usually what I do as well.
It is also possible to restrict the google search to a specific forum by appending the forum number to site:metalworkforums.com
eg metal work projects is forum 303 so the search term is "site:metalworkforums.com/f303"
The forum number can be seen by going to the forum of interest and clicking on the URL window
There is also a search function from within a thread that is often pretty useful.
28th Jan 2020, 02:38 AM #11
Hi Neevo,
I built this one !
https://www.gadgetbuilder.com/DrillSharp.html#Facet4
It works extremely well. There is a project write up on here somewhere.
https://metalworkforums.com/f65/t198...=facet+grinderBest Regards:
28th Jan 2020, 07:31 AM #12Philomath in training
- 6,541
28th Jan 2020, 07:38 AM #13Philomath in training
- 6,541
It's a nice thought guys, but if you look at the sort of thing being posted at the moment, I suspect that a dedicated grinding (or even toolroom) section would not be a well used sub-forum. While we have a number of discussions going on on all sorts of topics, very few members seem to be posting accounts of what they are doing.
28th Jan 2020, 07:58 AM #14Golden Member
- Mar 2009
- 54
- 825
28th Jan 2020, 12:16 PM #15Golden Member
- Sep 2009
- 666
gmf- douglas drill grinding attachment instuctions
By dodge at4 in forum METALWORK GENERALReplies: 8Last Post: 19th Dec 2020, 06:55 AM -
Which budget AC TIG?
By mark86 in forum WELDINGReplies: 10Last Post: 18th Jul 2019, 10:45 AM -
Four Facet Drill Sharpening and Grinding Wheel Dressing
By metaler in forum METALWORK GENERALReplies: 15Last Post: 20th Oct 2017, 07:52 PM -
Help Wanted - Drill Grinding Jig Without Instructions
By RoyG in forum METALWORK GENERALReplies: 29Last Post: 2nd Jul 2014, 03:10 AM -
$150 budget to get an arc werlder
By Gags_17 in forum METALWORK GENERALReplies: 58Last Post: 12th Apr 2007, 11:26 PM
