Results 1 to 1 of 1
Thread: Large drill grinder
18th Jan 2020, 01:55 PM #1Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Large drill grinder
SAM_0582.jpgSAM_0581.jpgThe old goat is back with a project. I have a drill grinder for up to 44mm drills. Conical point only. This different style attachment should go bigger, as well as being useful for 4 facet grinding on drills I can't do with an ER32 collet chuck. For drills up to 25mm the brass button is used in the transverse slot to index the drill. Over that size the axial slot is used. A micrometer depth stop will slide behind the drill and the edge angle set with a protractor on the base. The design has a change already and I'll put a pivot in the bracket as this will be easier than changing the wheelhead angle.
BC
Dawn drill press vice - LARGE
By racingtadpole in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 7th Dec 2018, 01:29 PM -
Drill Grinder. 4 6 Facet.
By BaronJ in forum METALWORK GENERALReplies: 87Last Post: 7th May 2016, 08:11 AM -
Christen 2-32 Drill Grinder
By C-47 in forum METALWORK GENERALReplies: 0Last Post: 26th Jul 2015, 11:27 AM -
Newcastle: Large mill / planer / grinder needed for job
By pippin88 in forum METALWORK GENERALReplies: 17Last Post: 7th Feb 2014, 08:42 AM -
Howto drill large hole?
By Norm.Mareeba in forum METALWORK GENERALReplies: 16Last Post: 22nd Oct 2006, 01:43 AM
