Results 1 to 6 of 6
Thread: Annular cutter grinding info
18th Jan 2020, 01:43 PM #1Senior Member
- Nov 2019
- Brisbane
- 69
- 452
SAM_0583.jpgHello from the old goat.
I have been grinding these cutters for 13 years and always have trouble with clearance on the following tooth. Today I tried to incline the workhead and set the wheel head to 0 deg. Could not get even close to grinding the tooth.
Now I scratch my head. How is it different? The grinder is reset back to how I've done it before and all is good. The newer cheap cutters have more flutes for the diameter in some sizes and grinding the inner facet is a pain. I am having to dress the wheel every 2 cutters.
BC
18th Jan 2020, 08:32 PM #2Most Valued Member
- 5,942
Have you thought about using a thinner grinding wheel, it may allow you to come in close???
19th Jan 2020, 10:37 AM #3Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Changing the wheel
Hello Kryn.
A saucer wheel would have to be thin and only worth a small number of dressings. My knees will shake. This grinder has no wheel hubs so I would lose a bit of a CBN wheel to dressing.
If I can find a cheap CBN saucer wheel will give it a go. So far they have been 2.4mm edge thickness and that rules them out.
BC
19th Jan 2020, 07:26 PM #4
I've not a lot of experience here, but a smaller wheel diameter would be needed to avoid hitting the following cutting edge. This problem is made worse when you have smaller cutters with a larger number of teeth.Best Regards:
19th Jan 2020, 08:54 PM #5Gear expert in training
- 34
- 1,075
I would have thought a thin flat wheel would be better suited to that task than a cup wheel, even just a cutoff wheel from an angle grinder
22nd Jan 2020, 08:36 AM #6Senior Member
- Nov 2019
- Brisbane
- 69
- 452
To use a smaller wheel will mean I need to spin it much faster and the T & C grinder is fixed speed. The hougan sharpener uses an electric die grinder and a small CBN wheel. The setup is muchly different.
A cut off wheel has the rong grain for tool grinding as they use regular A not 38A or 32A spec. Also grinding on the side of them is bad practice as it exposes the fibreglass and fragments shoot out.
BC
I think it is still a geometry issue.
Cutter grinding split point drills
By steamloco1954 in forum METALWORK GENERALReplies: 3Last Post: 2nd Jan 2020, 12:16 PM -
More cutter grinder info.
By steamloco1954 in forum METALWORK GENERALReplies: 10Last Post: 16th Dec 2019, 08:30 AM -
Rota broach annular cutter info
By Bill13 in forum METALWORK GENERALReplies: 33Last Post: 6th Feb 2016, 10:58 AM -
Annular Cutter Adaptor
By grunto in forum METALWORK GENERALReplies: 5Last Post: 13th Mar 2015, 02:27 PM -
Cutter Grinding Attachment
By Anorak Bob in forum METALWORK GENERALReplies: 6Last Post: 1st Aug 2011, 10:58 PM
