Results 1 to 8 of 8
    Charlestown NSW
    65
    1,673
    Default Quick and easy Drill Press table lifter
    My old Richardson Drill press doesn't have a factory table lifter. I assume that back in the 1930's you were expected to just use brute strength.
    Anyway I've got arthritis in my hands now so the table is getting a bit difficult to lift.
    I thought about various different ways of lifting the table including a winch with a cable and pulley, a counter weight etc etc.
    Eventually I realised a scissor lift car jack would do the job.
    Works well. Cheap and easy.
    heres a link to a video
    https://youtu.be/A7TeuRbDE6M
    peter
    Aug 2015
    QLD
    735
    Jack looks like it were made for the job...
    Oct 2010
    melbourne, laverton
    1,910
    Default sissir jack
    Thats interesting i bought a 12v car scissor jack for one of my drill presses a couple of years ago. I havnt got around to testing it out.
    aaron
    Dec 2013
    56
    1,418
    Nice work Peter
    Using Tapatalk
    7,189
    Looks Good Pete.
    A minor drawback I can see is the table can't be swung easily around the column.
    I got around this on my implementation by making up a curved plate and bolting that to the underside of the table bracket.
    A large Bearing was then attached to the top of the jack so the table plate just rolls over the ball.
    https://metalworkforums.com/f65/t203...nt#post1951688
    Charlestown NSW
    65
    1,673
    Looks Good Pete.
    Thanks Bob. I have a support ring on the column below the table arm. Lift the table, lift the ring until it's supporting the arm/table and clamp it. Then I can swing the table to any position and then clamp it
    Geeez, thats getting serious.
    peter
    Charlestown NSW
    65
    1,673
    Nice work Peter
    Thanks Dave, but nothing particularly special about it. Unusually for me, for once a job went easy.
    peter
    Dec 2013
    56
    1,418
    Quote Originally Posted by bollie7 View Post
    peter
    If it saves you and your hands it's worth it mate.
    I think somethings going on up our way, because like you have done everything I go to do lately just falls into place, or every bit of steel I need is there and almost the perfect shape etc. Jeff must be looking over me.
    The crane is in progress and going up as of tomorrow, and even the chain block spot turned out perfectly in the confined spot I've got.
    Using Tapatalk
  1. Waldown Drill Press Table
    By Anorak Bob in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 27th Sep 2018, 06:51 PM
  2. Drill press hold down table
    Last Post: 2nd Sep 2018, 10:00 AM
  3. Tough Drill Press RPM Table?
    By Burnsy in forum METALWORK GENERAL
    Last Post: 13th Aug 2014, 08:29 PM
  4. Accuracy in Drill Press a Quick fix
    By Abratool in forum METALWORK GENERAL
    Last Post: 30th Jan 2012, 10:30 PM
  5. Star picket lifter design - simple, easy DIY
    By gragra_in_oz in forum METALWORK GENERAL
    Last Post: 22nd Jan 2012, 09:27 AM
