Page 1 of 2 12 LastLast
Results 1 to 15 of 26
    Jul 2006
    Athelstone, SA 5076
    4,258
    Default Finally found a holy one
    Now for the restoration...or bin
    Does any know if they cast iron or cast steel?
    This will be a longterm project....need to drum up the nerve to fix or stuff it....lol
    How can someone do so much damage...the dark hole on fixed jaw is nearly 25mm deep while two others on the bottom go through to the bottom...they obviously didnt have a brain!!!
    Aug 2011
    4,779
    Hi mate,
    I got the same vice. I suspect they are cast iron.
    near Rockhampton
    6,218
    Wow, someone really molested that one.
    6,475
    I don't think I've seen a vise that nasty, ever
    Jul 2006
    Athelstone, SA 5076
    4,258
    Might be worse should i stuff up the resto...lol
    Aug 2011
    Perth, Western Australia
    67
    362
    Must have been a close cousin to the one who did this.
    Oct 2010
    melbourne, laverton
    1,910
    Default far out
    Quote Originally Posted by bts View Post
    I had a waldown table werse than that. no joke.
    Feb 2009
    Tasmania
    43
    Wow, that is a few steps beyond a "smile of shame". I suspect that someone has made a habit of engaging the automatic down-feed while they go and answer the phone, apparently never learning from the first mistake.
    Okay, I'll be the one to ask... How would one go about restoring such a tool? Tap and dowel the holes? Fill the holes with braze or weld? Stock up on JB weld and fill the holes with epoxy? Obviously, some choices will be governed by the base material, but it would be interesting to see how others would go about bringing it back to life.
    I suppose a heap of bronzed circles could be covered by paint or be a feature of the restored item hinting at it's earlier hard life. A work of art perhaps.
    6,475
    Hi Aaron,
    Quote Originally Posted by azzrock View Post
    I think I remember you posting a picture of it !
    Heathens I tell ya, heathens !
    Mar 2009
    54
    825
    G'day Richard,
    The one I fixed up for Dale was definitely grey CI.
    Yours looks like a good candidate for a cut an shut on the rails while I'd drill and plug the holes in the jaws. Some of the plugs will have to overlap but that shouldn't be a problem, just plug the big ones first and use a slot drill for subsequent holes so it doesn't wander like a drill will. Good luck mate.
    Greg.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    Quote Originally Posted by XJ9OX View Post
    Welding or brazing the CI is likely to distort it, so probably not the best idea. Anorak Bob has done wonders with plugs of CI into cleaned up holes.
    The problem with Eskimo's vice is that some holes are cosmetic (like those on the tops of the jaws) but some are in a 'structural' part of the vice (like those on the rails). While plugging will fill those holes, they will not restore the strength to the part. Even cutting those parts out and replacing with an untouched strip of CI will not fully regain the part strength.
    When I see parts like that I'm tempted to make up a pattern and just cast a new one...
    Jul 2006
    Athelstone, SA 5076
    4,258
    Hi mate,
    same vise...does yours have the same holes?...bet not hahaha
    Jul 2006
    Athelstone, SA 5076
    4,258
    yeah that is what I was thinking too Michael...the rails are quite bad, so I have decided I am going to TRY and weld with some rods a mate has given me..supposed to be for cast iron...he owned a welding business before he retired so I guess he has given me the right stuff...
    After all I do need the welding experience and no big loss if it doesnt work.
    Oct 2010
    melbourne, laverton
    1,910
    Default drill table
    Hi Aaron,
    joe from bendigo fixed that drill up for his son. He did a great job of it.
  15. #15
    6,475
    Hi Eskimo,
    Its a very long time since I did any cast iron welding ! I would make sure that you preheated it well, even if you are going to arc weld it.
    Having said that, I was taught furnace welding of cast iron, mending cracks in marine engine blocks. Hot heavy work for a 15 year old, my first job ! I got a City & Guilds certificate to prove it. The old guy that was teaching me was a real stickler for doing things right.
  1. Finally milling
    By azzrock in forum METALWORK GENERAL
    Last Post: 18th Apr 2017, 10:01 AM
  2. got one finally .
    By texx in forum METALWORK GENERAL
    Last Post: 16th Jun 2013, 08:56 AM
  3. Finally Finished My 260
    By kwijibo99 in forum THE HERCUS AREA
    Last Post: 16th Apr 2010, 01:53 PM
