Results 1 to 4 of 4
    Aug 2011
    4,779
    Default Bridgeport Clone Fine Feed Handwheel
    Hi all,
    Hardly ground breaking but it's another (little) step forward to making this mill "complete".
    It has been missing a fine quill feed handwheel since I bought it which has been a source of annoyance.
    Couldn't bring myself to purchase a plastic one so I re-purposed an alloy handwheel i had in my parts bin. It's probably a little large in diameter, but not by much looking at pics of Lagun milling machines on the net.
    I had to bore it out to clean it up and then make an adapter to mate it to the mill and clear the control box.
    The adapter is a nice press fit and the hole was reamed to 12.0mm for rather nice sliding fit.
    I was going to recess a 6mm cylindrical neodynium magnet to hold it in place when in use but it does not need it.
    The handle on the handwheel was cannibalised from a damaged ball crank handle from the table.
    I have a replacement for the table waiting...
    The forward/reverse pin was also missing so I made a replacement out of some scrap brass. Not totally convinced I like the colour but it works nicely so for now it's staying.
    Don't have a suitable knurl for the job so a series of evenly spaced grooves will provide some grip.
    Charlestown NSW
    65
    1,669
    Simon.
    Your hand wheel doesn't look out of place at all IMHO.
    Years ago I had an old flat bed, flat belt lathe that just had the old style 3 balls type winder like what you still get on the table feed on a mill. I hated that with a passion so I rummaged around in the odds and sods/scrap bin at work and found a valve hand wheel that was the right size. machined a bush similar to yours, machined most of the finger indentations off the OD, fitted a handle and fitted to the lathe. Made the old thing heaps better to use but unlike yours, mine still looked like a valve hand wheel
    peter
    Nov 2019
    AU
    52
    I like it. Vast improvement over the one arm deal they come with factory
    Sent from my SM-G930F using Tapatalk
    Aug 2011
    4,779
    Thanks guys. Sorry for the late reply, I wasn't expecting anymore replies to this thread.
    As for the brass forward/reverse plunger, I'll change that out. Last week I received a new clamp style knurl tool so I'll try it out.
  1. Bridgeport clone quill power feed - required or not?
    Last Post: 9th May 2019, 09:35 PM
  2. Cheap Bridgeport Clone in Vic
    By bwal74 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 8th Jul 2015, 07:11 PM
  3. BM30 - Manual Feed Handwheel question
    By denncarm in forum METALWORK GENERAL
    Last Post: 30th Sep 2013, 03:31 PM
  4. rigidity problems with bridgeport clone
    By the fabricator in forum METALWORK GENERAL
    Last Post: 16th Aug 2013, 03:58 PM
  5. Bridgeport Clone Ram Clamp
    By electrosteam in forum METALWORK GENERAL
    Last Post: 30th Jul 2010, 08:34 PM
