Results 1 to 1 of 1
20th Oct 2019, 09:21 PM #1Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
Sheet metal battery charger station
Had a couple of hours of shed time this arvo, decided to build a somewhat over complicated sheet metal affair with disruption form strengthening and solid rivets.. doesn’t everyone have shelving made with aircraft rivets and dimpled speed holes?
Made from 16G 6061 that I had floating around, the top shelf was a left over from a previous job that I forgot to measure twice and made 20mm too small across the short side. Rivets are 1/8” x1/4” before bucking, which means they are a fraction long technically but couldn’t be bothered cutting them and well it’s a shelf, not a Spitfire.
Still need to feed some plastic into the mill and make some racks for the spare batteries to slide into underneath the bottom shelf.
Li-Ion Battery to M18 Battery covertor?
By wm460 in forum METALWORK GENERALReplies: 5Last Post: 18th Feb 2019, 06:46 PM -
Anyone here a sheet metal guy?
By DSEL74 in forum METALWORK GENERALReplies: 10Last Post: 5th Nov 2017, 07:25 PM -
Moore and Wright charger
By shedhappens in forum ELECTRICALSReplies: 10Last Post: 9th Mar 2017, 11:06 PM -
Douglas Metal Shaper and Bramley Sheet Metal Folder
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 31st Jan 2016, 12:25 PM -
sheet metal job
By azzrock in forum METALWORK GENERALReplies: 0Last Post: 27th Nov 2011, 04:17 AM
