Page 8 of 8 FirstFirst ... 345678
Results 106 to 113 of 113
  1. #106
    Oct 2016
    470
    I found a couple of vids of Anders Johansson jet bike runs, for some reason he remove his channel but he has a new one now only found one with the engine that i will be using in the trike.
    https://www.youtube.com/watch?v=487HI4eK3uc
  2. #107
    Oct 2016
    470
    This one is one of my favorites, turn it up and hear the little JU-1 at full power I don't think i will be going that fast on the trike but will see
    https://www.youtube.com/watch?v=4Bqv9b5Ekms
  3. #108
    Oct 2016
    470
  4. #109
    6,480
    I don't think that I would like to be on the pillion at take off...
  5. #110
    Oct 2016
    470
    LOL!! just hang on tight
  6. #111
    Oct 2016
    470
    Been working on the trike on and off, done some mods to the gearbox support brackets slotted the holes so i have more adjustments for the engine and gearbox don't wont any of those parts touching the frame as it will be a bumpy ride. Put some Kool Wrap on the exhaust outlet as my back will be close to that exhaust. At last got the duct work done, was tricky to do but i think this will work As you can see i will be sitting on top of the engine, need some protection made up a FOD plate out of 6mm steel plate. The “family jewels” will be more comfortable with this plate in place
    Resize of IMG_8581.jpgResize of IMG_8588.jpgResize of IMG_8593.jpgResize of IMG_8598.jpgResize of IMG_8599.jpgResize of IMG_8603.jpgResize of IMG_8601.jpgResize of IMG_8604.jpg
  7. #112
    6,480
    Hi Turbine Builder,
    Nice work, I'm looking forward to seeing this machine in action !
    If that turbine let go there will be more than just nuts flying
    I saw that program on TV where RR blew a blade off the fan on a running RB211 ! A bit bigger than your little turbine but it would still be a big bang !
  8. #113
    Oct 2016
    470
    Hi Turbine Builder,
    Hi Baron J Thanks mate, got some time off work so can push harder to get things done. I think most of the hard work is done,so i need to work out were to put the rest of the auxiliary units. LOL nuts flying i hope not That 6mm plate will be fine,i have seen one of these size engines let go It's just goes BANG!!!! and bits of metal get shot out the back of the exhaust pipe ,but could of blown up on the side of the engine as well. I had a JFS 100 turbine as you can see it has a thick ring made out of inconel i think and the free power gearbox turbine wheel fit inside the ring so if that wheel lets go bits of metal will be contain inside the ring not blown out inside the aircraft.
  1. compressed aiir powered grease gun
    Last Post: 21st May 2015, 02:02 AM
  2. New Blower for gas powered forge
    By BobL in forum THE SMITHY
    Last Post: 1st Oct 2013, 12:27 PM
  3. Trike
    By Andy Mac in forum METALWORK GENERAL
    Last Post: 26th Oct 2006, 09:26 AM
  4. Drill powered piston shear
    By Bob38S in forum METALWORK GENERAL
    Last Post: 18th Oct 2006, 10:22 AM
