Results 91 to 105 of 113
Thread: Turbine powered trike
14th Aug 2020, 12:24 PM #91
14th Aug 2020, 12:56 PM #92Most Valued Member
- Healesville
- 2,129
1st Oct 2020, 12:24 PM #93
Not much of a update here, i cut down the work bench as i will need room once the trike is on wheels and i can roll it out.
Resize of IMG_8227.jpgResize of IMG_8228.jpgResize of IMG_8231.jpgResize of IMG_8232.jpg
1st Oct 2020, 12:31 PM #94
Made up a couple of 1/4 inch tubes for the oiling system for the pinon bearings. And Finish off all the welding on the rear end of the frame and clean up for paint.
Resize of IMG_8299.jpgResize of IMG_8298.jpgResize of IMG_8300.jpgResize of IMG_8303.jpgResize of IMG_8304.jpgResize of IMG_8305.jpg
1st Oct 2020, 12:34 PM #95
Well the diff housing is bent just a bit from all that welding, as you can see that aluminum plug should slide in without any interference. I can get them to fit but the 30mm rod is very hard to spin. So i found out the hard way, the right side of the axel when bolt down in the housing was fine and could spin the rod and i tried the left side no go it would bind and would not spin at all. So lessons learnt. I don't have oxy acetylene so tried LPG touch that was useless. I know a local engineering place not to far from me who can help me out, but because of our stupid government of victoria we are still in lock down. So nothing i can do at the moment.
1st Oct 2020, 12:55 PM #96
What about a bead of weld on the side you want to bend it too ?
Is a trick that has been many times to straighten diff housings after shortening, using either mig or arc.
1st Oct 2020, 01:40 PM #97
Yeah i was thinking of that method but will go with the heating with oxy and acetylene. I can work on other projects while waiting for his Lordship to ease more on restrictions. A couple of pics of what needs to be set up for straighten the diff housing.
1st Oct 2020, 02:07 PM #98
1st Oct 2020, 07:12 PM #99Most Valued Member
- Healesville
- 2,129
Turbs the tube is fairly thin so you probably will be able do it with your lpg torch, get a bucket of water and spot heat and then quench with a rag drenched with water. Do this several times along the side of the tube want shorten to pull the end where you want it to be.
I have used this technique several times with oxy/acet on much thicker material and it works well, the lpg might not get it hot enough but it would be worth a shot.....
1st Oct 2020, 09:27 PM #100
Hi shed, yeah i tried it a couple of times with the lpg torch the tube just springs back. I know Geoffrey at Lilydale Engineering the guys there will be able to help me out. It's a bugger they are 3 kms out of my 5 kms zone, just have to be patient in the meantime i have other jobs to do.
3rd Dec 2020, 02:23 PM #101
I found the large gas touch and that thing fix the diff housing, all good the wheel are spinning Got a couple of second hand tyres and new caps and finally got the trike on it's wheels. I think a 19 inch front rim will do, i was thinking 18 inch rim but with a 19 inch rim i can adjust the forks to make the trike level. And started work on the exhaust stack.
Resize of IMG_20201029_105215.jpgResize of IMG_8389.jpgResize of IMG_8392.jpgResize of IMG_8391.jpgResize of IMG_8329.jpgResize of IMG_8330.jpg
12th Feb 2021, 11:34 PM #102
Been a while, had to spend some money on the house some things need to be repaired. Been trying out tig welding not good, will keep at it,i have been looking around for a front wheel for the trike no luck here in AUS so got one from the US, not a bad price for it the rim and discs are in excellent condition for it's age. And got a new tyre fitted. Have some brake calipers on the way from the US as well with all the hoses, bolts, master cylinder, ect. . The trike sits a bit high for my liking, just have to live with it.
13th Feb 2021, 09:08 AM #103Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,183
13th Feb 2021, 03:29 PM #104
24th Apr 2021, 07:24 PM #105
Almost done with the duct work and engine mounts, just tack weld this short piece of ss tube for now need to make sure every thing is OK before i weld it all up, you can see i had to cut one end on a slight angle because had trouble getting the engine line up straight in the frame because the frame is a little bit bent it will work. I have some shim sheets to use to get the hole duct assembly set at the right height i machine slots in the engine base plates so i can move the the engine and duct work in and out as the NGV is a slip joint once the duct work heats up the NGV will lock itself in place.
Resize of IMG_8570.jpgResize of IMG_8571.jpgResize of IMG_8572.jpgResize of IMG_8573.jpgResize of IMG_8574.jpgResize of IMG_8575.jpgResize of IMG_8522.jpg
compressed aiir powered grease gun
By BobL in forum METALWORK GENERALReplies: 5Last Post: 21st May 2015, 02:02 AM -
New Blower for gas powered forge
By BobL in forum THE SMITHYReplies: 13Last Post: 1st Oct 2013, 12:27 PM -
Trike
By Andy Mac in forum METALWORK GENERALReplies: 3Last Post: 26th Oct 2006, 09:26 AM -
Drill powered piston shear
By Bob38S in forum METALWORK GENERALReplies: 8Last Post: 18th Oct 2006, 10:22 AM
