Page 5 of 8 FirstFirst 12345678 LastLast
Results 61 to 75 of 113
  1. #61
    Oct 2016
    470
    I have one of those diesel engines here for a future project, it needs a fuel leak repair and a clean out as it has been sitting for a while.
    I could get it going and you could test it to see if one of these is suitable for your needs.
    Personally i think you need to keep the weight down and the diesel engines have quite a heavy power to weight ratio.
    I was thinking about the generators that i built last night whike laying in bed, slowley my memory started coming back about what i was trying to achieve. I was trying to reduce fuel consumption so as the batterys charged and the load became less the engine revs would decrese, so by the time the batterys were close to full charge the engine would be running at close to idle and this is why i need the 1:2 belt ratio on my early prototypes.
    Running your engine 1:1 with an alternator should work fine at 3600 rpm, direction of rotation might be a problem and hp?
    I dont want be the bad guy here but i think someone needs to tell you, you can mig weld an axle if you are making a letter box.....
    But not an axle that you are staking your life on at 300 kph....
    High carbon steels in critical situations need preheating, low hydrogen rods, controlled cooling and to be done by a competent experienced welder with precision alignment jig.
    I think you need to take on board the sugestion that OXX made about cutting and resplining, the only thing that i might add to that is to get the ends proffessionaly anealed before cutting the splines then after they are get it rehardened.
    Cheers, shed
    Hi Shed,
    Yeah i was thinking of the weight as well, once i finish off most of the structural work will get back on getting the test stand set up and the engine and we will find out what needs to be done to get the best results. You not the bad guy mate, i had other people tell me about welding axles ect, ect my budget is low and can only do DIY stuff and this trike will not be going 300 kph and i never seen a trike go 300 kph, they are for cruising only. LOL i maybe only able to ride it on a short stretch of road, and if i can get a dyno power run we could get an idea of what it can do. There is a lot of unknowns with this project, the engine may run to hot or could grenade itself, the gearbox may not be suitable , ect , ect This trike will be heavy as i will need some type of birth shield around the engine, so if it grenade itself i wont have bits of debris entering my body so may use 3/8 stainless steel plates.
    Mark.
  2. #62
    Mar 2014
    South of Adelaide
    1,227
    Mig is low hydrogen. At work we regularly mig weld high carbon steels, its not some dark art.
  3. #63
    Apr 2012
    Healesville
    2,129
    Quote Originally Posted by Turbine Builder View Post
    Hi Shed,
    Mark.
    No worries Mark, pity, I was hoping to see you break the sound barrier.
    G/day snapa, yeah I mig it also but if the welded part is to be expected to withstand extreme loads and mortal safety is also a concern then it needs to be done properly.
    At this link you will find a list alloy steels, the axle is likely made out of one of these, in the PDF files to the right you will find the welding requirements and fillers https://www.voestalpine.com/highperf...n/alloy-steel/ then another complexity could be if the axle has been carbonized.
    I wonder if voestalpine and voldermort are related?
    cheers, shed
  4. #64
    Oct 2016
    470
    I got a lot done today, finished off one side of the steel structure. I flip it over as i forgot to leave room for the 1/2 inch bolt when i welded the cross section on the structure.
    Resize of IMG_7943.jpgResize of IMG_7945.jpgResize of IMG_7946.jpgResize of IMG_7944.jpg
  5. #65
    Oct 2016
    470
    Finished off one other side of the steel structure, weld in a couple of round stock in each end of the structure and drill 1/2 inch holes to bolt onto the plate.
    Resize of IMG_7951.jpgResize of IMG_7954.jpgResize of IMG_7955.jpgResize of IMG_7956.jpgResize of IMG_7958.jpg
  6. #66
    Oct 2016
    470
    I won't weld in this cross tube as i am waiting for a very important part for the gearbox that's coming from Canada, should be here next week.
  7. #67
    Oct 2016
    470
    The NGV arrive from Canada, wasn't cheap but i need to have it as i don't have one for the other Boeing gearbox and this one is not butchered up like the other NGV. I can still use it just have to make up the other parts that will fit onto it. As yo can see there is a bleed air duct will hook up a gate valve, this will help on start up of the engine as i can destroy the engine in ~ 10 seconds. I may not need it but it reassurance for me.
    Resize of IMG_7965.jpgResize of IMG_7962.jpgResize of IMG_7963.jpgResize of IMG_7964.jpg
  8. #68
    Oct 2016
    470
    Here is the NGV fitted to the gearbox, as you can see in the photos it's getting a bit cramped with this type of set up.
    Resize of IMG_f.jpgResize of IMG_a.jpgResize of IMG_b.jpgResize of IMG_d.jpgResize of IMG_e.jpg
  9. #69
    Oct 2016
    470
    Cut out the steel gusset and weleded in a new one. And yes i am overkill on this structure build Bit of a fiddly job to do, i found out the gearbox is off centre a bit i can make a new base plate or mill slots in the holes and centre up the gearbox that way, also the steel structure that bolts onto the side of the gearbox will need to be modified as well .
    Resize of IMG_.jpgResize of IMG_x32.jpgResize of IMG_x1.jpgResize of IMG_795.jpgResize of IMG_791.jpgResize of IMG_792.jpgResize of IMG_793.jpgResize of IMG_794.jpg
  10. #70
    Oct 2016
    470
    lots of welding and grinding i have been doing, at last got most of the work done on the diff, had to grind my crappy Welds and re weld . I welded on some Steel gussets on the two long diff perches just to give it a bit more strength. Tack weld a nut for the vent tube and sealed up with JB weld. Cut off the square tubes on the frame will redo the side structure supports for the gearbox with rectangle tubes and use shoulder bolts to hold everything together. The two steel tabs on the side of the frame i will weld a tube in between the them they a quite solid and will help in strengthening the frame.
    Resize of IMG_7968.jpgResize of IMG_7974.jpgResize of IMG_7973.jpgResize of IMG_7988.jpgResize of IMG_7978.jpgResize of IMG_7976.jpgResize of IMG_7977.jpg
  11. #71
    Oct 2016
    470
    Got some work done on the steel structure on the rear end of the frame, gave it some paint and welded in more Steel gussets.
    Resize of IMG_8005.jpgResize of IMG_8002.jpgResize of IMG_8003.jpgResize of IMG_8004.jpg
  12. #72
    Oct 2016
    470
    Got some V clamps , looks like i may have to pull the bigger clamp apart and cut it to size. The one that is closest to the size was ~25 mm short if i use this clamp i think it may leak.
  13. #73
    Oct 2016
    470
    Got 16 mm thick plate to machine up the two v band flanges and got a scrap piece of ss tube will have a go at making a concentric reducer.
  14. #74
    Oct 2016
    470
    Time for a update, redone the side support structure for the gearbox welded in solid round steel stock inside the tubes and steel gussets plates and drill to size for shoulder bolts, nice and strong support for the gearbox now.
    Resize of IMG_8022.jpgResize of IMG_8023.jpgResize of IMG_8025.jpgResize of IMG_8028.jpgResize of IMG_8026.jpgResize of IMG_8027.jpg
  15. #75
    Oct 2016
    470
  1. compressed aiir powered grease gun
    Last Post: 21st May 2015, 02:02 AM
  2. New Blower for gas powered forge
    By BobL in forum THE SMITHY
    Last Post: 1st Oct 2013, 12:27 PM
  3. Trike
    By Andy Mac in forum METALWORK GENERAL
    Last Post: 26th Oct 2006, 09:26 AM
  4. Drill powered piston shear
    By Bob38S in forum METALWORK GENERAL
    Last Post: 18th Oct 2006, 10:22 AM
