Results 16 to 25 of 25
30th Sep 2019, 11:31 PM #16Most Valued Member
- 2,666
Progressing, should be done in another couple of cuts.
1st Oct 2019, 08:44 AM #17Most Valued Member
Nice work. Coming along.
I got shaper envoy BTW!
4th Oct 2019, 04:35 PM #18Most Valued Member
- 2,666
Masport chipper/shredder shaft repair
Made some decent progress.
Got the steady bits finished to the point where it's functional.
Picked up a suitable bearing to go on the shaft, built the shaft up with the MIG and got it all in the lathe.
Then realized I'd made another minor miscalculation.
I couldn't get the steady to where the supports lined up with the bearing, as it hit on the side plate of the chipper rotor.
So I made up a quick bearing support out of some scrap.
Then got on with turning it to size. Finally got to this point.
It's definitely not to nuclear power station spec, but better than I started with!!
4th Oct 2019, 04:44 PM #19Most Valued Member
Could be Chenobyl standard?
Good work.
5th Oct 2019, 12:21 AM #20Most Valued Member
- 2,666
Cut my first ever keyway on the shaper. Turned out better than I expected.
Bored out the pulley, made press fit plug for the hole and fitted it.
Bored to fit the shaft then realized I need to make an internal keyway tool for the shaper. I knew that 1" allthread I've been moving around my sheds for 20 years would come in handy one day!!
It's just the right size to fit in my large tool holder.
Couple of progress photos.
5th Oct 2019, 07:33 AM #21Most Valued Member
Looking good!
9th Oct 2019, 10:21 PM #22Most Valued Member
- 2,666
Keyway cut, drilled and tapped for a couple of grub screws to make sure the pressed in pulley center can't move.
Also drilled and tapped for a keyway grub screw as the original wasn't coming out - even once the mushroomed end was removed during boring.
Only key steel I had was 8x10 and I needed 6x6 so reduced a piece using the shaper.
Felt like a slight overkill - a bit like using a sledge hammer to drive in an upholstery tack
Next step is to reassemble it
10th Oct 2019, 12:20 AM #23
Hi Steve,
Very nicely done !
I would have done exactly the same to make a key. It wouldn't be the first time I've filed a piece of the square bar as used between door handles down to make something like that.Best Regards:
10th Oct 2019, 10:35 PM #24Most Valued Member
- 2,666
Basically back together again - just needs a couple of seconds with the grinder to trim the key to length and the belt guard can be refitted.
The key was a firm tap to fit but went in smoothly, so hopefully it's all snug enough that it won't flog itself to death again. Time will tell....
11th Oct 2019, 05:19 AM #25Most Valued Member
Nicely executed!
Disc sander from crappy wood chipper.
By Tuomas Soikkeli in forum METALWORK PROJECTSReplies: 0Last Post: 12th Apr 2019, 06:46 PM -
Garden shredder/chipper
By Briangoldcoast in forum GENERAL DISCUSSION / OFF TOPICReplies: 16Last Post: 3rd Oct 2015, 02:06 PM -
Replacing Worn Out Belly Pan in 18" Wood Chipper
By Acco in forum TRAILERS & OTHER FABRICATED STUFFReplies: 3Last Post: 5th Jan 2012, 11:46 PM -
Shaft repair
By Bryan in forum METALWORK GENERALReplies: 9Last Post: 9th Jun 2010, 08:44 PM
