Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 102
  1. #61
    Aug 2011
    4,779
    All good.
    I got three things on the go and I don't work all that fast at best so a no tg of chit chat in between is good.
    Thanks Bruce. I'm still keen to set up a copper plate. Your mirror finish on the blades is a work of art.
  2. #62
    Sep 2010
    Port Sorell, Tasmania
    74
    All good.
    Simon, if you do set up your copper plate for polishing I for one would appreciate a brief description of the process.
    Tony
  3. #63
    Nov 2017
    Geelong, Australia
    57
    2,665
    Not that I've done a lot of scraping, but I've found using diamond lapping disks on a small bench grinder gives an good finish.
    Like this:
    https://www.ebay.com.au/itm/Grit-300...c/272614867753
  4. #64
    Aug 2011
    4,779
    Yea recently bought one of those too.
    I never realised you could get a finish with a copper disc until Bruce mentioned it. Anyway, see how we go...
  5. #65
    May 2012
    Vermont 3133 Victoria
    248
    The copper disc is loaded up with diamond paste. You could use cast iron or aluminum I just happened to have a copper disc.
    Bruce
  6. #66
    Aug 2011
    4,779
    Oh. I see.
    You wipe it on and it impregnates into the surface. Yea they did that with cast iron at the scraping class.
    I have diamond paste in various grit sizes so I'll come up with something.
  7. #67
    Mar 2014
    South of Adelaide
    1,227
    Quote Originally Posted by argeng View Post
    I went to the AJAX auction, there was a Biax and a RENZ,
    after auction rip Biax would cost 1500 RENZ 1200.
    That's actually a pretty good price considering they are $5-6000 new. I was lucky i picked up my coborne for $150, no where near as good as a Biax or Renz but it does the job.
    Just in case you need another project simon, Robin Renzetti has just shown on instagram how he converted a old reciprocating saw into a power scraper, might be a affordable option for you.
  8. #68
    Aug 2011
    4,779
    Actually I've been looking at that. Joe Hovel made one a few years ago. By all accounts he reported reasonable good results for the price. I think he used an Aldi machine.
  9. #69
    Dec 2013
    56
    1,418
    I'm sure Stuart posted up about modifying one many years ago, sadly I don't see him on here these days. I was in contact with him a year or 2 ago through email.
    He was moving to a big a better shop on a property.
    Using Tapatalk
  10. #70
    May 2012
    248
    The Diamond paste is loaded into the lapping disc, a bearing mounted onto a shaft works so you can push it into your lapping plate.This embeds the diamond particles into your lapping plate. I haven't measured the SFP of my setup but it is not fast. I can measure if anyone wants to know.
    A couple of years back there was a lapping machine at my local scrappy, I didn't buy it but probably should have. It used copper plates, they were marked in grit size.
    Its not rocket science when we are just doing 2 small edges. In saying that the copper loaded disc does give great results, Marko favorably commented on the edges that I lapped.
    Bruce
  11. #71
    May 2012
    248
    G'Day Snaptap,
    Coborne, now they are rare as. I Probably could have picked one up a few years back. I was thinking about buying it and giving it to Phil M. It would have been a great talking point if the scraping classes went forward.
    Bruce
  12. #72
    Dec 2013
    56
    1,418
    Bruce
    Very interested in this as I'm not anywhere near up on scraping and sharpening.
    I have a really nice big certified surface plate, a new Sandvic scraper and also one of Phil's beautiful homemade ones etc (both from him)
    Could you take a picture, I'm trying to figure out your bearing idea, but can't visualize it.
    Using Tapatalk
  13. #73
    Aug 2011
    4,779
    Hi Dave,
    From my understanding, you get an old bearing with and OD of around 30 - 40mm and press it onto a shaft which will be the handle.
    Then, the disc which is attached to your bench grinder or whatever is lightly smeared with diamond paste and then switched on so it's spinning. You then present the bearing outer race (that you have on a holder) to the surface of the disc while it is spinning. The motion of the bearing turning while pressed onto the disc impregnates the diamond into the disc surface.
    I remember now seeing Phil and Marco show us at the scraping class.
  14. #74
    Jul 2010
    9,088
    I think I've made the same mistake that a lot of inexperienced hand scrapers do..... go too light with the scraping at the start. I really should have hacked into it on the first few cycles.
    Yes, way to much playing around at the start. Way to many points before getting full(or close to full) bearing.(for what my opinion is worth) But then it was sure a valuable lesson when I learnt it.
    Are you spin testing?(by your last picture it looks a little heavy on the ends)
    Not 100% sure I like the scrape first and worry about alignment later, although given the part and the machine I don't see any huge issues either..... but then I am 100% sure I wouldn't necessarily know.
    Still, looks good so far even if you did a few more cycles that you'd do on the next one.
    oh he is around now and then, just dont say his name three times Only came across this thread as there was mention of it in Simons powerfeed thread. I did a thread on my Buniax but the pictures are all gone. I'm sure I have them here if anyone cares to see them.
  15. #75
    Aug 2011
    4,779
    Hi Stu, great to hear from you.
    Yea maybe I should have had a couple of looks at alignment just to see where it is and how I need to be tracking. It may bite me on the !
    I have looked at the mounting where the clapper attaches and it seems to be pretty dam close to perpendicular, surely that's a good start. Realistically I figured that any misalignment in droop can be taken up when I attack the ways on the actual machine. Or, I could just plane the top of the box when done.
    Horizontal alignment however is not that easily mitigated but I won't know until I put the ram back on the machine and use my $100 granite square to take some measurements.
  1. Shaper, 18" Macson (Alba) shaper Brisbane
    By pedro54 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 9th Jul 2019, 12:02 PM
  2. Macson shaper gib adjustment
    By Pete O in forum METALWORK GENERAL
    Last Post: 10th Jul 2018, 11:54 PM
  3. Douglas 10" shaper
    By Grahame Collins in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 26th Oct 2016, 10:31 AM
  4. Victoria Macson 18" metal shaper for sale
    By Toggy in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 9th Jan 2016, 10:05 PM
  5. Macson 18" swing lathe
    By Matt_M in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 13th May 2015, 09:59 AM
