Results 31 to 45 of 102
27th Sep 2019, 09:03 AM #31Senior Member
- May 2012
- Vermont 3133 Victoria
- 248
G’day Simon,
Do you want to borrow any straight edges. I have 1 with dovetail edge and a couple of other plain ones.
Cheers Bruce
27th Sep 2019, 05:04 PM #32Most Valued Member
Thanks Bruce. PM sent.
I'm up to about cycle no. 26 on the underneath of the ram.
It doesn't seem to be getting any better or any worse in terms of the contact area. In short I'm starting to chase my tail.
I'm going to have a think about my technique. The amount of blue I'm using and my scraping technique.
When you start chasing your tail it usually means your not doing something right or your not seeing something that you should be.
As it stands it's a 1000 times better than when I started.
It's got to be reasonable flat, I can't place a 0.02'smm feeler gauge under any part of the ram when. It's on the plate
I might start putting together a jig to measure the parallelness of the dovetails.
27th Sep 2019, 06:46 PM #33Philomath in training
- 6,563
Simon, to me that does not look too bad. I think you are at the stage where it is mostly flat but there is a bit of droop at the ends. Unfortunately that means the whole lot has to come down in level to clean up those low spots. Biax time usually.
doing well though.
27th Sep 2019, 07:01 PM #34Most Valued Member
Thanks to rf the input and encouragement Michael.
Those end bits are really taking their sweet time to "come up".
They don't even look worn as such. It makes me wonder If they were low from new but that does not make sense. Certainly it does not make sense to me for the rear or the front part of the ram to be low in relation to the rest.
How can you preferentially wear the front and rear?
Biax time you reckon? I won't lie it's been bloody hard work by hand. There's a bit more surface area than those small blocks we did in the scraping class!
Luckily Bruce has been generous in his offer of a lend of his biax.
Looking forward to using it. I've got approx 2 minutes experience with one so it will be interesting!
27th Sep 2019, 07:55 PM #35
28th Sep 2019, 12:09 AM #36
Hi Simon, Guys,
Just thinking out loud !
If the ram was not tightened down enough, wouldn’t the act of pushing the cutter through the work tend to lift the front and push the rear down. Also the arm pulling the ram forward would tend to pull it down at the front until it hit the work and then lift it.Best Regards:
28th Sep 2019, 01:46 AM #37Most Valued Member
BJ, you'd need to check the area where the ram runs to ascertain that theory. It is a very good possibility though.
28th Sep 2019, 09:37 AM #38Most Valued Member
Hi guys. Yea I suspect they are all plausible theories.
I had a bit of a play yesterday, I cleaned up the base and put the ram back in place. While the ways on the base need to be scraped, I can already feel the difference with what I have Done on the ram. It slides quite nicely.
Hope to get a few more scraping cycles in today. See where we get.
28th Sep 2019, 12:16 PM #39Golden Member
- Apr 2018
- Drouin Vic
- 635
I'm watching this thread with interest as i have the exact same shaper, in pretty much the same condition as your starting point. I'm thinking you should offer an exchange reco service.
28th Sep 2019, 01:20 PM #40Most Valued Member
Ha yea great. Watch my mistakes and have a laugh at my expense!
The scraping by hand is not easy work but that aside I'm having a bit of fun and it's an intersting journey so far. I think a shaper is a great machine to start your first machine scraping project. Also if your shaper is in similar shape to mine then you won't need to worry about making it any worse. You can learn and hone your scraping skills as you go and still be confident your are making improvments.
I'm not looking forward to scraping the underside dovetails on the base. That will be awkward.
28th Sep 2019, 07:35 PM #41Most Valued Member
- Healesville
- 2,129
28th Sep 2019, 07:51 PM #42Most Valued Member
I've just taken possession of Bruce's (argeng) biax scraper so when I get home from work tomorrow I'm going to cut sick with it and have a go!
That should speed things up......
Either that or I'll dig myself a hole!
29th Sep 2019, 11:49 AM #43Most Valued Member
OK. first go at using a biax machine.
A few of observations from a novice;
1) They are really efficient at scraping and make the process much less arduous;
2) The stroke adjustment helps produce very consistent scraping patterns;
3) Very easy to take more material away than is required;
4) You really have to re-adjust your scraping style and learn again
5) With great power comes great responsibility!
6) It still gets bloody heavy after a while!
At this stage I can only manage to scrape left to right. I can't sway back and fourth like I have seen Nick Mueller do!
In summing up:
I want a Biax!!
No pics yet of my latest effort. I have to duck out. I'm almost scared to blue it up and have a look!
29th Sep 2019, 01:51 PM #44Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Scraping Blue
I have tried various Prussian Blue powders & grease oil mixtures, without much luck.
However the Blue that seems to work for me comes out of Repco Auto shop, its called "Power Plus Bearing Blue Stock No PP103" in a 25 ml tube.
Have done a lot of scraping with it & very happy with its performance.
Bruce
29th Sep 2019, 02:24 PM #45Most Valued Member
Thanks Bruce.
I have been finding that my homebrew stuff is very stiff to smear out on the plate. I heated it up in bath of boiling water and added mixes or oil and then also thinners but it's still very stiff.
Two days ago I bought some Prussian blue my Permatex which seems easier to work with.
I'm keen to try some water based Canode but it seems difficult to get in Aus.
I'm finding that the ambient light and angle plays a big part too.
Also seems to be a fine line between not enough blue so it becomes hard to see/read and too much so that it creates smears and fault spots. Also the amount movement on the plate of the part when you are spotting plays a part too.
If you rub the part back and fourth too many times you start to get too much blue collecting and creating false spots.
Shaper, 18" Macson (Alba) shaper Brisbane
By pedro54 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 9th Jul 2019, 12:02 PM -
Macson shaper gib adjustment
By Pete O in forum METALWORK GENERALReplies: 5Last Post: 10th Jul 2018, 11:54 PM -
Douglas 10" shaper
By Grahame Collins in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 26th Oct 2016, 10:31 AM -
Victoria Macson 18" metal shaper for sale
By Toggy in forum METALWORK - Machinery, Equipment, MARKETReplies: 7Last Post: 9th Jan 2016, 10:05 PM -
Macson 18" swing lathe
By Matt_M in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 13th May 2015, 09:59 AM
