Results 1 to 5 of 5
    Sep 2011
    Ballarat
    65
    3,103
    Default Pickering governor rebuild
    Hi all
    as some of you know I am restoring a Pickering governor. I will continue this thread here as it started in the general discussion area and seemed to grow a bit. The first part is here:
    https://metalworkforums.com/f306/t20...achining-setup
    To recap I have done the outrigger arm bearing and after a lot of research it seems the previous 'rebuilder' has garnished bits from a (few) different size governor/s. While some bits are almost the same there are slight differences for each size of governor.
    The flyballs on this governor are the wrong ones and are well worn so I decided to see if I could make new ones with the limited machinery and tooling I have.
    Aside from one massive error it turned out ok.
    Phil
    20180328_152121.jpg 20190907_082156 copy.jpg 20190905_083257.jpg 20190905_083732.jpg 20190905_085132.jpg 20190905_085148.jpg 20190905_114911.jpg 20190905_120158.jpg 20190905_120204.jpg 20190905_121455.jpg 20190906_092203.jpg 20190906_154540.jpg 20190906_150254.jpg 20190907_082137.jpg
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    So what was the fix Phil? Weld up (or plug) and redrill, or remake from scratch?
    Either way, well done. I especially like the 'improved clearance' tool holder. Is this the same governor that you re-bored or is this another one in the collection? Looking at the initial photo, is the pulley damaged or is that a trick of the light?
    PS With a texta, write on that piece glass "remember, you have a surface plate"
    May 2011
    Murray Bridge S Aust.
    5,959
    A town I used to live in was called Pickering, in the early days, yet the bay was called Wool Bay, which eventually the town was called, if it could be called a town of about 8 houses.
    You never cease to amaze me Phil. You turn out some beautiful work and with such limited machinery too.
    Sep 2011
    Ballarat
    65
    3,103
    Hi Michael
    nah, it's the same governor. It's just the more I look at it the more I find wrong with it.
    There will be a complete new ball. It would be remiss of me to put a 'repaired' new component on.
    The pulley is damaged but will have no effect on the belt that drives it. Most governors are broken on the pulley flange.
    If I forget to use that surface plate one more time I will be declaring myself insane...seriously!!
    Phil
    6,473
    Hi Phil,
    Very nicely done, your skill and attention to detail put my work to shame !
    As far as the forgetfulness is concerned, I can't remember what I had for dinner yesterday
  1. Hercus +rebuild with DRO
    By NickMortimer in forum THE HERCUS AREA
    Last Post: 17th Jun 2016, 09:14 AM
  2. ARM Rebuild Questions
    By rickw72 in forum THE HERCUS AREA
    Last Post: 17th Aug 2012, 12:22 PM
  3. Trailer rebuild
    By artme in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 29th Jan 2012, 11:15 PM
  4. 9" rebuild
    By 12bolts in forum THE HERCUS AREA
    Last Post: 20th Jan 2012, 07:38 AM
  5. Hercus rebuild
    By Big Shed in forum THE HERCUS AREA
    Last Post: 10th Sep 2009, 01:56 PM
