Results 1 to 10 of 10
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Default Tricky aluminium project
    Pam and I have been travelling for the past 3 months in our (15year old) Ford Transit mobile home.
    On the way, a couple of oil changes were due. I had to use considerable force to remove the plastic (PA66-GF30) oil filter cap, which on refitting cracked and leaked.... So I cleaned it thoroughly and repaired it with epoxy. That didn't hold pressure... So I tried to order a replacement, only to find that they are no longer available! Eventually I found an aftermarket one which needed significant filing of the large buttress thread to make it fit.
    I decided to make a new one from aluminium on my return to my workshop.
    It's done now and I'm pleased with the fit and quality.
    I made it out of a piece of flat bar 65mm thick, cutting an octagon on the bandsaw before turning it on the lathe. Finding and grinding a threading tool for buttress thread and setting it all up was achieved without mishap.
    The tricky bit was a set of pegs inside which hold the bypass valve. Difficult to measure, mainly. Eventually I cut the old one in half to understand and measure thicknesses.
    Here are a couple of pics of the progress.
    Cheers, Joe
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    Great job Joe, well done. I'm sure that it last for years.
    All The Best steran50 Stewart
    6,480
    Hi Joe,
    Very nicely done
    My old van didn't have the drain plug on the bottom and I bought an expensive socket to unscrew it to get the thing off and sealed when I put it back on. I hated having to do an oil change on that thing.
    Aug 2011
    4,779
    Nice work Joe.
    Hope you and Pam enjoyed your travels. Sounds like you are well set up!
    Aug 2009
    Sydney, NSW, Australia
    1,844
    Wow if that isnt quality i donno what is, must have taking many hours to produce such a job well done two thumbs up
    Oct 2006
    Newcastle
    124
    Nice work
    Hafco AL320G Lathe
    Toolex RF31 Mill/Drill
    Saber Bandsaw
    Dec 2018
    NSW
    586
    Looks familiar.
    Is it the 2.2L TDCi donk?
    Aug 2010
    72
    3,105
    No, its for our 2.4 l TDDI donk.... identical oil filter though I believe....
    Cheers, Joe
    Apr 2018
    Drouin Vic
    634
    Great job and vary interesting from where I sit; the Land Rover Defenders from 2008 to end of production had the Ford Transit (Puma) motor, first 2.4 then 2.2L. A cracked oil filter housing in some of the remote outback locations ours has been to is not a pleasant idea to contemplate.
    Dec 2018
    NSW
    586
    Great choice of vehicle.
    For the apparent amount of work involved in the manufacture of a new oil filter housing, it might be more viable to create a filter relocation plate and associated hoses to move the filter tree, 'cooler and filter proper to a different location.
    I wouldn't be surprised if that cover (plastic) is also seen in other makes of vehicles. I have not measured, but I could almost swear the missus' Hyundai diesel has the same filter cover and filter.
    And in the auto game, where there is lots of models with a non OEM part... there is bound to be variants made out of other materials etc.
  1. Tricky machining job
    By Old-Biker-UK in forum METALWORK PROJECTS
    Last Post: 7th Jan 2017, 12:14 PM
  2. A little aluminium project
    By WelderMick in forum WELDING
    Last Post: 2nd Aug 2013, 10:29 PM
  3. what would be a better project
    Last Post: 26th Jun 2012, 06:22 PM
  4. How will I sharpen these tricky little suckers?
    By FenceFurniture in forum METALWORK GENERAL
    Last Post: 25th Mar 2012, 01:36 PM
  5. A tricky bit of turning
    Last Post: 9th Jul 2010, 02:02 AM
