Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    near Rockhampton
    6,218
    I have got the longer sections bent up that I can not do on my Magnabend. It went easier then I thought and also harder as the machine gets in the way and we could not bend symmetrically, so we measured a bend and bent away from the line to suit and it seems to have worked out fine.
    It makes you understand the versatility of the magnabend type machine when you try a pan brake and find it gets in the way of some bends.
  2. #17
    Jan 2004
    Mackay North Qld
    6,446
    Quote Originally Posted by tontonh View Post
    Well, at the moment I'm tolerating your 'thread'.
    I am not tolerating yours.
    Serial trolls have no place here. You are banned again !
  3. #18
    near Rockhampton
    6,218
    Have got it pretty well done. Have to weld up some gaps and pop rivet the tabs in.
    Has worked out OK but I am still no fan of doing sheet metal work. Certainly a lot harder then meets the eye.
  4. #19
    near Rockhampton
    6,218
    It is fitted to the trailer now. It holds the hydraulic powerpack to power a tipper ram. Just waiting on some hydraulic bits and a latch for the top. I have a 12V to 12V battery charger to install in the box as well. I might also put the breakaway controller in there as well.
  5. #20
    May 2011
    Murray Bridge S Aust.
    5,959
    Don't know if you're interested, but we fit a small solar panel on the tool boxes to keep the batteries topped up for the tippers and winches on the trailers we make. Can get panel details for you if need be.
  6. #21
    near Rockhampton
    6,218
    Thanks, the battery charger I have also has a solar panel input, but I decided not to use it due to the sort of work the trailer will be doing and the fragility of the panels.
    I just charge the battery via by wiring up the tow cars to feed 12V to the reverse/auxiliary pin and tapping power off that. It also feeds the breakaway battery.
  7. #22
    near Rockhampton
    6,218
    It works well, although the ram has five stages, I really should get the fifth stage welded to the fourth stage so it can not be extended. It gets to 46 degrees just with four stages, and I think if the fifth was to be extended, it will bend the ram as the swivel joint up the top runs out of movement.
  1. Bending and welding sheet steel?
    By Matt Milner in forum METALWORK GENERAL
    Last Post: 26th Jul 2019, 07:15 PM
  2. Help with sheet metal bending
    By ned3000 in forum METALWORK GENERAL
    Last Post: 19th May 2019, 12:37 AM
  3. Replies: 21
    Last Post: 17th Jan 2013, 06:39 AM
  4. How to score 2.4mm stainless sheet prior to bending
    By Chela in forum METALWORK GENERAL
    Last Post: 25th May 2011, 10:20 PM
  5. Repairing metal scuffs and polishing sanding lines
    By chris330 in forum METALWORK GENERAL
    Last Post: 30th Oct 2008, 12:11 AM
