Results 1 to 5 of 5
    Apr 2019
    Finland
    46
    117
    Default - Two in one belt sander angle grinder attachment -
    Hi
    This is my two in one angle grinder belt sander attachment.
    Video: https://www.youtube.com/watch?v=64Nm...z&index=3&t=5s
    Video is from the making process:
    Sander can be used as an traditional belt sander.
    Or hand held pipe / curve sander, show video below:
    Wanted make it easy to mount / unmount and to be used without tools.
    I use it with cordless grinder, which makes it portable.
    I have used it to clean welds, removing paint and zinc coating from pipes and shaping wood.
    Used skateboard wheels couple first months.
    But then i turned new drive pulley from nylon, without any actual reason, skateboard wheel worked nicely, just wanted little more "professional" look to it.
    Mar 2009
    54
    825
    Very clever design Tuomas and well executed.
    Thanks for sharing your work.
    Greg.
    Apr 2019
    Finland
    46
    117
    Quote Originally Posted by kwijibo99 View Post
    Greg.
    Thank you. I tried to find the simpliest way to make it.
    "Pipe sander" is a compromise, wanted to use it with both, wood & steel.
    For polishing pipes it would have been better if the lower arm is swiveled, then it sands larger area.
    But when sanding down welds or shaping wood.
    I noticed that its better that it sands only from the area that user can see. Then its easier to sand welds to surface level or get desired shape to wood.
    Not so effective as a pipe polisher than swiveled models, but more accurate as a sander.
    Nov 2010
    Gippsland Victoria
    733
    Default Angle grinder cuts
    Thanks,
    I didn't realise that all sorts of shapes can be cut with an angle grinder. It was very useful to see whats possible and some ways of achieving complicated shapes.
    Bill
    Apr 2019
    Finland
    46
    117
    Quote Originally Posted by steamingbill View Post
    Thanks,
    Bill
    Thanks.
    Specially with flap wheels one can easily make curves with angle grinder, both internal or external.
    That's why i use mostly straight flap wheels instead of tilted ones.
    I like that those fit better to shaping, than tilted ones are better when grinding something to surface level.
  1. Home made belt sander attachment.
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 6th Jun 2018, 09:29 PM
  2. Looking for old belt sander - see link
    Last Post: 5th Jul 2016, 07:57 AM
  3. Disc and belt sander
    By Maxi77 in forum METALWORK GENERAL
    Last Post: 26th Jun 2015, 10:17 AM
  4. My new belt sander
    By Stustoys in forum METALWORK GENERAL
    Last Post: 24th Mar 2011, 09:40 AM
  5. using belt sander as linisher
    By Com_VC in forum METALWORK GENERAL
    Last Post: 25th Nov 2007, 02:42 PM
