Results 1 to 4 of 4
Thread: My take on a King Way tool
25th Sep 2016, 01:20 PM #1Golden Member
- Mar 2009
- 54
- 825
My lathe lives on a cabinet mounted on hardwood risers which allows me to use a pallet jack to move it when I need to as I store stuff behind it.
Every time I shift the lathe I recheck the bed alignment to be sure nothing has moved.
In the past to do this I used a pair of V blocks, a precision level (0.1mm/M) and a feeler gauge. A V block was placed on each way with the level resting across them. An appropriate feeler gauge was then placed as needed to bring the bubble to an appropriate location. Something like this:
Starting with the level furthest from the headstock the V blocks were aligned against the saddle and the level adjusted with a feeler gauge.
Using the saddle, the level was then moved to about the centre of travel and the level reading noted before moving to the headstock end.
If necessary the bed adjusting feet were tweaked and the process repeated until the deviation was satisfactory.
This method worked ok but care had to be taken because if the level moved on the V blocks at any point during a pass then it had to be repeated which could make the whole process a bit time consuming.
I decided it was time to build myself a King Way aligning tool but with somewhat of a twist. I didn’t want to drop a heap of coin buying precision vials for a tool I might use once every six months or so, rather I decided to come up with a method that facilitates the use of the precision level I already have. Here’s my solution:
The frame itself is just a joe basic King Way setup to which I added a tilting rest which supports the level itself.
The rods are 16mm 1045 which is what I had to hand and I milled flats on them which makes lining everything up quicker but the flats are not necessary.
The cross shape of the tilting level rest means the V base of the level is supported at three points making it very stable which allows me to complete a check of my lathe in a couple of minutes with the level readings being much more consistent than when using V blocks.
The slide is made from 1” 1045 BMS and is drilled and tapped at 180⁰ and 150⁰ to allow use on both V and flat lathe beds or dovetail ways.
The level tilt can be adjusted by either the M6 X 1.0 cap screw or by using feeler or slip gauges under the embedded ball bearing.
Now I know that a King Way tool has two levels perpendicular to each other but for my purposes the single level is good enough for now.
The tilting rest does allow me to use the level along the bed if I use a couple of V blocks. Again my lathe is far from level so the tilting rest allows me to make this check with minimal fuss.
Something I found interesting is that a greater deviation of the level occurred with the ball foot resting on the flat of the bed than when it rested on the opposite V way which actually supports the saddle. I suspect this may be caused by the level movement being larger as the effective pivot length becomes shorter.
When I get a chance I will do a check with the ball foot on the flat way and an indicator on the V way to see if there is any actual variation.
Deviation with ball foot on flat way.
Deviation with ball foot on V way.
Given that on a Hercus the distance between the rear V way and the opposite flat is only 100mm and between the V ways themselves is only 130mm then the deviation as per the level is within 0.02mm over the 600mm measured.
I know the lathe turns true as I just made up a 400mm crank shaft rod which was within half a thou end to end and I’m happy with that as long as nobody tells Schlesinger
Greg.
30th Sep 2016, 06:10 PM #2Most Valued Member
- Healesville
- 2,129
Very nice kwijibo, did you make brass plugs to go under those adjustment bolts ?
I reckon that you have
2nd Oct 2016, 12:04 PM #3Golden Member
- Mar 2009
- 54
- 825
Thanks shed, I've got to confess that I was too lazy to bother with brass feet for the screws, they don’t need to be done up super tight so there is only minimal marking to the rods.
I performed a more complete survey of my lathe yesterday and got it all pretty good with a couple of minor tweaks, of course the proof will be in the using the next time I turn something with a bit of length.
First check was rear V way to front flat way which indicates the alignment of these ways is pretty good from the head stock to around half way but starts to go pear shaped between there and the tailstock end. Note the slab mill is just there as a counterweight to keep everything balanced on the narrow ways.
If I’m reading things correctly:
The level indicates that the flat way falls from the middle to be lower than the rear V way by 0.03mm give or take.
The DTI indicates the front V is either higher than the flat way by 0.03mm (0.09 – 0.06) or out of parallel to the rear V way by something similar or a combination of both.
Next check was rear V way to front V way which indicates the alignment of these ways is pretty consistent end to end.
Both level and DTI indicate a deviation of a bees dick less than 0.01mm.
Because the ball foot of the frame is riding on the angled surface of the V way it is impossible to say if this deviation is due to a difference in height or parallelism.
Last check was for parallelism between the rear V way and the tailstock V way which indicates they evenly converge by around 0.04mm over the measured length.
The level deviates within 0.01mm give or take.
The DTI moves out by just short of 0.04mm which if I read things correctly indicates a deviation in parallelism.
Next step from here would be to get a test bar and take more measurements against that but to be honest I’ve never really had any problems producing accurate work on this lathe and can’t see any point in spending money going down that particular rabbit hole.
Doing these tests has definitely been worthwhile though because I'm now fully aware of what problems are there and will know when I need to work around them.
By the way, thanks to Anorak Bob for the little combination DTI which he very kindly sent over, this is the first time I’ve had a chance to use it in anger and it’s a little ripper.
Greg.
3rd Oct 2016, 10:40 AM #4.
- 6,459
Inspirational work Greg.
And I'm glad the little Mitutoyo has proven useful.
BT
I want to know what is this tool name and what is used for
By Gimy in forum METALWORK GENERALReplies: 2Last Post: 29th Jan 2016, 07:44 PM -
Best tool?
By Old Hutcho in forum METALWORK GENERALReplies: 30Last Post: 12th Oct 2012, 08:06 PM -
any one here know what this tool used for ?
By thorens in forum METALWORK GENERALReplies: 11Last Post: 21st May 2012, 08:31 PM -
Parting tool mounted on rear tool post advice needed
By colbra in forum METALWORK GENERALReplies: 17Last Post: 12th Feb 2012, 02:49 PM -
Tool Box... well a bit more than just a tool box
By Anorak Bob in forum METALWORK GENERALReplies: 2Last Post: 5th Apr 2011, 01:12 AM
