Results 46 to 56 of 56
Thread: Old McPherson lathe for learner?
10th Sep 2023, 12:42 AM #46
99 times out of 100 its a cheap power device that fails, I've repaired the motor on my mill a number of times and the speed controller only once. That cost me the grand sum of £3.95 plus £2.75 postage, and I still have two devices as spares.
I've recently replaced the motor completely with a bigger one from a treadmill.Best Regards:
10th Sep 2023, 12:47 AM #47
Can you believe everything they write on the internet?
Here is the youtube video showing the motor replacement: https://youtu.be/I7UU_MoaieI?si=TOg6vUIUSGnk02a2
I will save you the hassle and post the photo here:
You just need to read the thousands of forum posts and watch the thousands of youtube videos on Sieg lathes and mills as I did for over a decade that I owned them
Go to those websites, zoom in on those images, the labels clearly say 350W, and google those model numbers while you are at it.
There is no indication those are 500W motors.
10th Sep 2023, 01:07 AM #48
Hi Kafie, Guys,
It doesn't matter how you spin it !
The input power will always be greater than the output power !
Add up the losses, the heat generated, the effort just to keep the motor spinning in its bearings, the conversion from AC to DC and associated switching losses. Non of these are listed so output power values are probably the most honest way to rate the motors.Best Regards:
10th Sep 2023, 02:25 PM #49
Senior Member
- Sep 2011
- 228
Just adding my 2c here, in the last few months I picked up a nice hobbyist lathe and mill for $1000 combined, maybe curb your enthusiasm and put the feelers out for both, you'll probably save at least a grand and end up with much better gear...
10th Sep 2023, 02:29 PM #50
Senior Member
- Sep 2011
- 228
I should say it was all due to the great members on this particular forum!
10th Sep 2023, 08:39 PM #51
Senior Member
- Sep 2011
- 228
Photos to prove it
10th Sep 2023, 08:52 PM #52
Hi Richard,
Nice lathe ! A bit of spit and a polish needed.Best Regards:
10th Sep 2023, 08:56 PM #53
And some elbow grease but you have yourself a machine shop now
10th Sep 2023, 09:13 PM #54
Senior Member
- Jul 2023
- 109
10th Sep 2023, 09:20 PM #55
Senior Member
- Sep 2011
- 228
10th Sep 2023, 10:06 PM #56
Senior Member
- Jul 2023
- 109
Yeah, but I could also do worse for the same money.
As a couple of much more experienced members pointed out in posts #2 and #3 in this thread, I don't know enough to judge whether an old machine is right for me, or even in satisfactory condition. I could get lucky with an old machine or just some expensive scrap metal.
The new Sieg combo is a safer option for me. If it doesn't work I can take it back for refund or repair, unlike a used machine. The Siegs also don't require refurbishment or repair, which would take time away from other things I'd rather do.
There's also a space issue in my workshop which makes the compact Siegs more attractive, especially as they'll just be occasional use machines and can't justify the footprint your machines have.
McPherson Lathe Information
By Fargo in forum ANTIQUE AND VINTAGE MACHINERYReplies: 6Last Post: 8th Aug 2016, 02:41 PM -
McPherson's Hercus lathe booklet
By Tinkerer77 in forum THE HERCUS AREAReplies: 4Last Post: 5th Jul 2016, 11:40 AM -
WHICH GAS FOR TIG LEARNER
By Normanby in forum WELDINGReplies: 15Last Post: 9th Nov 2014, 11:20 PM -
MIG Gas for a learner
By DBACT in forum METALWORK GENERALReplies: 3Last Post: 8th Nov 2013, 05:39 PM -
McPherson Lathe
By zuffen in forum METALWORK GENERALReplies: 26Last Post: 19th Dec 2011, 09:42 AM
